My M1-atx is draining my battery
  • My M1-atx is draining my battery
    Thank fully i have a manual i've been push starting the car because the battery has been dying alot. What's the deal with this thing. My wiring is as follows
    6 g. wire from battery to the m1-atx and grounded 6g. wire to the m1-atx, and the big white plug from the m1-atx to the motherboard. that's all that is wired. Also after installing this car pc my ECU blew which was a $1100 dollar Hondata K-pro ECU. Dunno where to start with that problem
    Take a look at the M1-ATX manual.
    You need to wire up to the ACC/IGN line as well and set the ABCD jumpers on the M1-ATX.
      ah that makes sense. let me go give that a shot thanks
        It's still draining my battery. My battery is dead every morning.
          Are you charging it? After it is fully discharged you can't expect to get enough charge from driving it. Also, batteries don't like to be discharged. It may well be dead if you discharged it fully. Take it to a shop and have them check the battery. If it is good, then charge it overnight.
          My Work Thread:
          http://www.mp3car.com/vbulletin/showthread.php?t=72552
          Source switcher for Lill
          http://www.mp3car.com/vbulletin/show...d=1#post841007
            Heres a diagram of my wiring now.
              How do you have it jumpered? I'm assuming the M1 has jumpers similar to the M2.
              Current Vehicle: 2007 Dodge Nitro
              Second Vehicle: Sold it :( 2005 Dodge Ram 1500 Quad Cab
              First Vehicle: 2003 Ford Ranger
                5sec/45 second is the setting.
                  i just looked it up. Our jumpers are the same thing. I'm using setting 1 with 1 jumper on A.
                    If, as you say, you have needed to push start it several times, your battery is probably shot. This ALSO could be the cause of your ECU failure. Jumpstarting can cause a large spike in voltage in the system, perhaps your ECU didn't like it.
                    Have a mechanic check your battery (or check it yourself with a voltmeter to start), I bet the battery is no good anymore.
                    Michael
                      I figured out what the eCU problem was, it was a bunch of fuses and i fixed em. How do i charge the battery other than leaving the car running?
                        Battery charger.. Seriously.. Where do you live?? Autozone will test your battery for free to see if your wasting your time.. Drive it down there.
                          Ah alright i'll take it to autozone then.
                            Check your alternator while you are at it. Should be >13.5v with the engine running.
                            Unlikely, but could you be drawing more amps to your carPC and sound system than your alternator can supply?
                              When I installed my carpc I connected the battery to the ignition wire on the M1-ATX (stereo harness was labled wrong!). M1-ATX drained my battery, too...shouldn't it shut down no matter what when the battery voltage gets too low?
                              Asus MicroATX with GeFore 6100, Mobile Sempron 3300+, 1Gig Ram, 320GB 3.5" 7200UPM HDD, M2-ATX, Gain/Xenarc 7"
                              Fast IS my copilot
