Do I need -5V for an AT
  • Do I need -5V for an AT
    I have a DC-DC power supply model: MDP-8051S , it doesn't have -5V.
    do I really need it?
    if I need it, how can I get that voltage?
    Im using Irman, and serial character LCD from Crystafontz.
    anybody using this PS?
    www.mp3commander.tk
    That really depends a lot on the motherboard you are using. I'm running an embedded mobo which only requires +5v and +12v for example.
    Rob
      not essential, BUT serial ports and some onboard sound cards need -5V to function..... since you have an Irman, your gonna need it!....
      unless you can use a USB ---> serial converter.... since the USB port only has 5V+ in its plug......
      Project - GAME OVER :(
        Can I do this?
        www.mp3commander.tk
          No, you can't do that, the input to the -5volt regulator should go to the -12volt rail..
          2 week temp ban (spam and complaining about deleted posts)
          register another account and you're gone for good.
            Sorry that was a mistake. now should be ok.
            www.mp3commander.tk
              Yes, that will be fine. Though I would also put a 10uF capacitor at the input of the regultor, and add a 0.1uF unit at the output. The result will be a much more stable -5V.
                do you mean like this?
                sorry for my ignorance, I don't know much about electronics.
                www.mp3commander.tk
                  Ahh, I don't think you need the 220uF on the output..
                    Aaron Cake I need your confirmation...
                    www.mp3commander.tk
                      That should do. Though I would switch the position of the 220uF and 10uF capacitor. And change the 10uF to 100uF.
                        This is what I did.
                        the Output is droping like -2V
                        And the 7905 gets extremly hot. WHY??
                        Is something wrong?
                        Somebody help me!!
                        www.mp3commander.tk
                          Well, if you have wired it like that, it should work... If you are having problems, then you probably haven't wired it like that..
                            Try the regular 7905 instead of the L. Also, you will need a heatsink on the regulator regardless. How much current are you trying to draw through it? Is one of your capacitors bad?
                              problem solved. I thought that the 7905 pinout is like the 7805.
                              That was my mistake.
                              7805:
                              1. input
                              2. ground
                              3. output
                              7905:
                              1. Grund
                              2. input
                              3. output
                              Thank you for your help.
                              www.mp3commander.tk
