Power cable splicing
  • Power cable splicing
    OKay I was unsure on where to post this at (power supplys or lcd sections) but I fiqured that people who know alot about power would look at these fourms so...
    OKay I want to extend the power supply cable on my lilliput monitor. I have the cable that connects to the lilliput, to a small fuse box, and then to a cigerate light port, and a cigar lighter cable with nothing attached to it. Basicly I have one of these:
    http://i9.photobucket.com/albums/a63/girbot/lil4.jpg
    *note: this is not the same as the one I have (mine is a black square box)*\
    and this:
    http://i9.photobucket.com/albums/a63.../cig-large.jpg
    I want to cut off the plug part on the lilliputs and attach the longer cable one.
    I know this is not rocket science and I should have no problem doing this. I just want to know:
    1. If its possible and wont set the car a-flame
    2. which would be the best way to do it
    3. what do you think about my idea?
    You know you're an engineer if you have no life & can prove it mathematically.
    and this:
    Cut the wire, solder the extension to the old wire, cover the bare wire (where you have the solder) with electric tape. You will be fine.
    Final Touches
    Car: 2002 Mitsubishi Magna EI
    CarPC: SP13000, M2-ATX, 512 MB RAM, 120 GB 2.5" HD, X-Fi Sound Card, Xenarc 700TSV, Garmin 18 USB.
    Audio: 2X15" Rockford Punch Z, 1 Rockford Punch 2-ch Amp, 1 Soundstream Lil Wonder II 4-ch Amp
      after reading your 2 sentence reply I came to a startling conclusion....
      Why diden't I think of that?!?
      any way thanks for the reply, I am sadly a novice to soldering and was wondering how I should do it. I know I heat up the cables being soldered but do I use that solder material stuff?
        You don't heat up the cables, you heat up the tin solder.
        Yes, you will need the tin solder material. There are hundreds of write-ups on soldering techniques. search google for them. i had a nice one with videos but its on my favorites at home. When i get back I'll post the link for you. It is quiet simple.
        If you find soldering difficult and want an alternative, you can use wire junctions or strip terminals to join separate wires. The only problem is that they are huge compared to the wire size, and in some applications (space tight areas) it is difficult to find a place for them
        something like these:
        Final Touches
          Ya I think I will be going with soldeing. Where my monitor is mounted extra space is hard to find. I will hit up google for a soldering guide, but a video one would be great.
            ok here it is:
            http://www.boxgods.com/dept/modding/...Article&ID=190
            Final Touches
              My 2 cents:
              Cut the wires 1 inch different in legnth, then your soldered connections will be staggered to reduce the chance of a short.
                okay so you just slip on the heat shrink tube and use a blow dryer or something to shrink the tube? These can be used instead of soldering? Are these better, same, worse then soldering?
                Thanks for the link ramy_zohair, this is A LOT better then ones I have been looking at.
                  No. Heatshrink is to protect the wire, not join it. If you twisted it together and then heatshrinked over it, it might work, though think it would pull apart pretty easy.
                  Get a butt connector. You strip off a little bit of the end of each wire (1/8-1/4 inch)
                  You stick the wire in one side of the connector, crimp it with a crimp tool or with pliers. Then you put the other wire in the other end and crimp that. Done.
                  The only reason you'd use heatshrink is to protect the join. Say if one side pulls loose it doesn't short something out. You could use electrical tape as well.
                  GE Cache Builder | [email protected] |Coolstuff :autospeed.com | bit-tech.net | Nitemax Ultra Pinouts
                    The Butt Connectors are typically easier and cheaper than going the route of soldering - especially if you don't already have a soldering iron and other required stuff....
                    I used butt connectors a lot - all you need is a crimper. Make sure no bare ends are sticking out of the butt connector and you should be fine - or just wrap them with a little (electrical) tape.
                    www.mobile-effects.com
                    Free file hosting, picture gallery hosting for installs, PM me.
                    Internet's first Front End Skin browser, featured installs, downloads, links, informative articles - all free to registered users.
                      I have used my share of butt connectors too. I prefer solder, but in your case I would say only invest in all the extra stuff if you plan on soldering a lot down the road. If you use good crimpers like Klein or Chanellock (my preference) the butt connector is very unlikely to ever fail.
                        I like soldering, it gives you stronger cleaner connections. The butt connectors are good if you need to remove something frequently or if they are needed for easy access for repairs. If you need help soldering ... I would search the forums here theres pleanty of good advice. Also, you dont really have to worry too much about seting your car on fire because usually the worst taht can happen is that you blow a fuse....
                        -good luck
                        Brown 2010
                          Okay last post:
                          So I get one of these:
                          and use one of these:
                          to seal it as such:
                          Question: I have to use two right? one for pos and one for neg. Also the above pic is not what I am going to do but a quick pic I found for example.
                            WOW those things worked like a charm. I got some butt connectors and a crimper/cutter/stripper and went to work. I was amazed on how easy it went. This is my method of choice now for wire extensions. Thanks for surgesting them guys.
