Help with Carnetix P1900 and Aopen Mini pc
  • Help with Carnetix P1900 and Aopen Mini pc
    I currently have everything set up and running but my pc is not going into stand by when I turn off the ignition. I have it set up the following way
    Inputs
    primary connected to battery positive
    black grounded to chassis
    yellow to the ignition
    Outputs
    pc positive connected to primary
    pc negative grounded via black wire
    second positive running to display (set to 12v) and grounded
    green & black wire soldered to pc power button according to instructions and connected to jumper 3 on the P1900
    What am I doing wrong?
    Does it go in stanby when you press the button?
      Yea, it does go into standby when I press the button. Any ideas?
        How bout when you touch the two wires soldered to the power switch together?
          Haven't done that.
            If that puts the minipc in standby then the only thing i can think of would be the what the p1900 shutdown delay time is set to. Are the wires you soldered to the on/off button hooked up to the Acpi relay on JP3?
              They are set to JP3 and I believe I set left the default delay time
