So how do I get the PSU to turn on on ING?
  • So how do I get the PSU to turn on on ING?
    today I was doing the final connections and when I turned the key on IGN, nothing happened w/ the PC... is it supposed to turn on by itself or do I have to do any other things? I did connect the psu to the motherboard so that shouldn't be the problem..
    I tested the wires with a DC voltage tester and it did work so there is current and the connection to the PSU is good.. the problem is somewhere from the PSU because I hooked up my Xenarc to the PSU and that did not have any power either so it's the PSU but what about it?
    Emo
    What PSU are you using?
    If you're using an AC PSU and inverter, then no, it won't turn on automatically.
    How about the Wiki?
      sorry, I forgot to tell you that.hahah
      no, I'm using the OPUS 150
      so it should turn on automatically but why is not doing that?
      -Emo
        double-check your wiring here: http://www.mp3car.com/vbulletin/showthread.php?t=53523
        also, the motherboard-switch-connector-wires on the 150 (black & red) seem polarity sensitive, so try changing the positions on one of the ends.
        Dr. Ron Paul for President 2008
        Hope for America - http://www.ronpaul2008.com
        Who is Ron Paul? - Why do we need Ron Paul?
        CarPC Newbs Start Here: All your questions answered, as if by E.S.P.
          well damn it worked!!! lol I switched the Power On cable polarity like you said and that seemed to do the job!!!
          Thanks tj!2k4 for the help! (you too DarquePervert)
          -Emo
            excellent! you're welcome
