Usb hub power source?
  • Usb hub power source?
    What are people using for usb hub power source? I have a powered 2.0 hub upfront and a pcmcia usb/firewire card that has a ac adapter as well. I am using a fair amount of power hungry devices so I need the power (my sound card won't run off the hub unless its powered. Last year I used a power inverter and the ac adapter, but every time I had to crank for whatever reason I would royally screw up my system.
    The hub wants I think 5 volts and the adapter has 10 - 13 I think on its adapter... sorta strange. I will also have an external media drive which runs off of 12 volt so I was thinking of a 12 volt conditioned supply and using it for the adapter too, but what about 5 volt... a point of load?
    5v line from a HDD power connector on the PSU.
    How about the Wiki?
      unfortunately I have a laptop
        Another Solution...
        I'm using this 5V regulator from Radio Shack to power my:
        • Hub
        • DVD-Rom
        • Touchscreen
        • USB Camera
        • GPS Receiver
        Keep in mind, though, that it only handles 1A (x 5V = 5W) at most... So don't overload it.
        Put it on a heatsink or screw it into something metal.
        For Sale: Carputer (CarPC) & RCA Y-Adapter
        Newsflash: Take a look at my unsold stuff above, thanks!
        Up Next: Make an OBD to Serial cable & Redo the "MMI buttons"
          holy crap... thats alot of stuff on that rig. I built a supply for my liquid cooling system using those and a 12 volt one, but they are rated 1 amp... my hub alone is rated 2.5 amps... then my media drive is rated at 3.5 I think... thats alot of them... I decided I would probably overheat them in the summer and start loosing devices which is worse then dealing with the power inverter.
          thoughts on my calculations? They way off?
            RexBruMet Skin for FrodoPlayer
            Nissan Aux-in MOD
            Originally posted by bgoodman
            We're an international forum, post in whatever langauge you like.
