Usb hub power source?
  • Usb hub power source?
    What are people using for usb hub power source? I have a powered 2.0 hub upfront and a pcmcia usb/firewire card that has a ac adapter as well. I am using a fair amount of power hungry devices so I need the power (my sound card won't run off the hub unless its powered. Last year I used a power inverter and the ac adapter, but every time I had to crank for whatever reason I would royally screw up my system.
    The hub wants I think 5 volts and the adapter has 10 - 13 I think on its adapter... sorta strange. I will also have an external media drive which runs off of 12 volt so I was thinking of a 12 volt conditioned supply and using it for the adapter too, but what about 5 volt... a point of load?
    5v line from a HDD power connector on the PSU.
    How about the Wiki?
      unfortunately I have a laptop
        Another Solution...
        I'm using this 5V regulator from Radio Shack to power my:
        • Hub
        • DVD-Rom
        • Touchscreen
        • USB Camera
        • GPS Receiver
        Keep in mind, though, that it only handles 1A (x 5V = 5W) at most... So don't overload it.
        Put it on a heatsink or screw it into something metal.
        For Sale: Carputer (CarPC) & RCA Y-Adapter
        Newsflash: Take a look at my unsold stuff above, thanks!
        Up Next: Make an OBD to Serial cable & Redo the "MMI buttons"
          holy crap... thats alot of stuff on that rig. I built a supply for my liquid cooling system using those and a 12 volt one, but they are rated 1 amp... my hub alone is rated 2.5 amps... then my media drive is rated at 3.5 I think... thats alot of them... I decided I would probably overheat them in the summer and start loosing devices which is worse then dealing with the power inverter.
          thoughts on my calculations? They way off?
            http://www.mp3car.com/vbulletin/show...light=meanwell
            Thanatos.
            RexBruMet Skin for FrodoPlayer
            Nissan Aux-in MOD
            Originally posted by bgoodman
            We're an international forum, post in whatever langauge you like.
