Can a carpc psu be used to charge the car battery?
  • Can a carpc psu be used to charge the car battery?
    I know they sell this http://www.campingworld.com/browse/p...D=1768&src=FPC
    But its a lot of $$$. I was wondering if the carpc psu be use like that? How would you have a on and off switch added? I go to car show and it would be nice to have my car power from the building electric so my battery don't die. If anyone have idea or suggestions, please let me know.
    Thanks,
    Charlie
    www.Yellowmann.com
    Once A Yellowmann, Always A Yellowmann ...One Who Is Wise - Always Learn From Other People's Mistakes ...One Who Thinks That They Can Never Be Successful - Will Never Be Successful ...First You Don't Succeed - Try, Try Again ...
    If you're using the building's electricity, can't you just use a normal trickle charger?
    -psyrex
    Gen 1: Pentium 3 1GHz - ATX - 2005
    Gen 2: Pentium M 1.6GHz - ITX - 2006
    Gen 3: Pentium M 2.0GHz - 5.25" SBC - 2007
    Gen 4: (coming soon: Core2 Duo - 3.5" SBC - 2009)
    ...it never ends
      -psyrex
        Cheap and safe to use a good trickle charger.
        http://www.batterytender.com/
        TruckinMP3
        Read the FAQ!
          Thanks for the reply but for shows, the car power need to be running and a inverter like the one I will will give it constant current. I pretty sure the trickle charger only charge when the car is off. Any other idea?
          This one will work but $$$$ http://batterytender.com/product_inf...21a8cc15d37ff0
          www.Yellowmann.com
            If you just want to power the CarPC, temporarily connect a standard PSU.
            If you want to power the whole CAR off AC, you're going to need something a hellofalot beefier than a PC power supply. You'll have to spend money on a unit.
            I had something similar powered off two 12v car batteries, when the thing was in the pit area, i'd have it charging off a 20a Boat charger. I think that cost around $200-$300.
            Converting from AC to high-amp DC isn't a cheap thing to do, apparently.
              Yeah I was afraid to hear that but this is the best for the price so far I found. http://www.campingworld.com/browse/p...D=1768&src=FPC
              www.Yellowmann.com
