Does anybody use OPUS 120PSU with MB870? - Problem
  • Does anybody use OPUS 120PSU with MB870? - Problem
    Hello, I have ITX case from OPUS with OPUS 120PSU It`s rebooting when come to Windows XP logo (tested a lot of times) sometimes (rarely) it`s boots to the end & then reboots again, but with normal (desktop) ATX PSU it`s not!
    its wired by 20 ATX connector & 4-pin P-IV 12V connectors from DCX.3.120p to motherboard Ibase MB870 but it works also with only the 20 ATX connector.
    Tried with AC power loss - off/on/previous state - same result
    I used for tests:
    Pentium 4 2.4GHz (512KB)
    & Celeron 1,7GHz (128KB)
    & Celeron 2.0Ghz (128KB)
    with 256MB DDR memory & even 128MB DDR, - same results
    So the total power consumption is much lesser than 120Watts
    LED - blink 1 time after I turn on system, then it`s green all the time & is green before, after & in time system rebooting. (not blinking or smth.)
    also I tried to test memory under DOS & used SEM (like SNM in windows) to test stability it works fine (under DOS).
    also I noticed that voltages are not same from DCX.3.120P & my ATX are not the same, and voltages from DCX.3.120P are changing all the time.
    voltages (from BIOS monitoring):
    ATX DCX.3.120P
    1.50 1.49-1.53
    3.39 3.35-3.39
    5.16 5.01-5.08
    11.97 12.20-12.22
    -11.78 -12.40-12.61
    3.12 3.11-3.15
    5.09 5.01-5.06
    There is no additional stuff connected to the MB (like USB/PCI devices & so on), also tries to connect HDD with another power supply - with no result.
    So it`s rebooting inminimal configuration like: MB870 + CEL 2.0 (have lesser power consumption than CEL 1.7 (52.8W against 63.5W)) + 128 DDR RAM
    Also doublecheked all temp - they are not more than 50`C.
    http://www.mp3car.com/vbulletin/showthread.php?t=68636
    It's not jst total wattage draw that matters. The Opus 120w can provide up to 42 on teh 12v rail.
    The P4 2.4Ghz has a max draw of 57-59w
    The Celeron 1.7Ghz has a max draw of 63.5w
    The Celeron 2.0Ghz has a max draw of about 53w.
    There's your problem!
    How about the Wiki?
      But OPUS have over load protection.
      3 flashes of LED why it`s not warning me that way?
        I used the MB870 with the OPUS 150W for over 1 year with no problem. You could just have a faulty OPUS.
          In opus I was told that they doesn`t guarantee work with high amperage on 12v rail.
          waiting now for m2atx. & selling opus 120w
