Keep CarPC running on Petrol Stations, etc
  • Keep CarPC running on Petrol Stations, etc
    Hi,
    I've done some work on a wiring diagram how to keep the carpc running if you're on a petrol station, atm or something.
    How it works:
    Hold down Switch S1 and turn off ignition.
    Relay K1 pulls and keeps itself alive - constant 12V on remote of M1/M2 or whatever.
    If you turn on the ignition again K2 opens the circuit for K1 and the relay falls back to it's old state. The next time you just turn off the ignition without pushing S1 the powersupply (M1/M2) will shutdown like usuall.
    2+2=Quattro
    Audi S6 2.2 Turbo
    RNS-E Headunit
    Helix HX400=AXTON Amp
    Audi Doorspeakers and 15" JBL in Sparewheel Hole
    19" Alutec Alloys, ABT-Silencer, FK-Suspension
    That's pretty neat. Why not just put a switch on the IGN line to the power supply? Just trying to get away from that?
    Nick
    '99 Ford Escort ZX2 CarPC <-- RIP Feb '07
    2006 Chevy Equinox LS (Current Project)
    **VIA EPIA PD 1ghz Mobo, OPUS 150, 7" LinITX LCD touchscreen, 512 Ram, 60Gig HD, DLink Bluetooth, Belkin 802.11g wireless,
      You can put a switch in the ignition line, but than you have to turn it on and off all the time.
      With the above wiring you just push the button once to keep it running and the next time you turn on the ignition everythings goes back to it's old behavior.
      That way, u can't forget that your carpc is on "allways on" mode.
      Germans allways want more than just an "on / off switch".
      2+2=Quattro
      Audi S6 2.2 Turbo
      RNS-E Headunit
        Check this thread.
        http://www.mp3car.com/vbulletin/show...3&postcount=21
        -WarDriver-
        -WarDriver-
        Server Administrator
        Outdoor Nut
        My DC to AC Inverter Mod
        My Laptop Remote Switch
          On the M1 or M2 you don't need a shutdown controller. The wiring is only to keep the carpc alive if you're just leaving for 5-10 minutes. Otherwise if u pull the key or turn off the ignition the carpc will shutdown or hibernate or whatever.
          With this u just push the button and you can leave and lock the car like usuall but the carpc will remain running.
          2+2=Quattro
          Audi S6 2.2 Turbo
          RNS-E Headunit
