3.3volts...whats it for??????
  • 3.3volts...whats it for??????
    Did a search and couldnt fint the answer. AT suplies obviously dont have a 3.3volt line. So what does it do?
    Re: 3.3volts...whats it for??????
    Originally posted by Genesis
    Did a search and couldnt fint the answer. AT suplies obviously do have a 3.3volt line. So what does it do?
    I don't believe that my AT supply has 3.3v. (desktop supply that is) I will check when i get home, as im at uni now, but I'm 95% sure that it only has +/- 5 and +/-12 volts
    http://www.mp3vl.tk Plans and progress on my install - (Updated 28 June 02)
    Australian mp3car Portal
    mp3car related links Check them out / Add some
    mp3car FAQ - RTFF
    [########==]80% Assembling
    -=Current Progress: Working Sproggy supply, building box.=-
      Yeah I know, my at deskop supply doesnt have it either. But what is it for? I built my sproggy with the 5volt and the 3.3 volt, but I cant figur out what this is needed for. I may as well use 2X 5volt ic's and doublt the 5volt current.
      My motherboard has both at and atx connectors. may as well use the AT one.
        memory and processor voltages I believe
          hey buddy the ATX funtion requires 3.3 and At funtion dont cause the mobo converts it onboard
            Thought so.
            Thanks everyone.
