Can I bench test my carpc using a battery charger?
  • Can I bench test my carpc using a battery charger?
    My battery charger is adjustable either 2 or 6 amps. I have the opus 150 watt power supply and currently I am using a standard power supply as I get everything installed. Before I mounted the pc in my car I wanted to test it using the battery charger. Anyone see and issue with this?
    Dr. Ron Paul for President 2008
    Hope for America - http://www.ronpaul2008.com
    Who is Ron Paul? - Why do we need Ron Paul?
    CarPC Newbs Start Here: All your questions answered, as if by E.S.P.
      Ya. It is not meant for that.
      2-6 amps MIGHT be enough. Why not just get another ATX supply and use that? THey are pretty cheap these days.
      Michael
        So i guess that is not a good idea? I would think it would be no worse than a car cranking and alternator spikes, but not sure
          I have one and built and loaded the system using it i just wanted to be sure the opus will give me all the power i need with no issues before i put it in the car
            Considering the Opus only outputs 5A, it should work fine
            How about the Wiki?
              Use can use an ATX PS to power the Opus to make sure it will run your carputer. I am looking for a link that describes it.
              Michael
              Here are some
              http://www.dslreports.com/faq/9208
              http://forums.techpowerup.com/showthread.php?t=25
              You then just cut off one of the molex HD connectors, and use the Yellow for 12 volts ( I think it is yellow is 12 volts, and red is 5, but I could be mixed up on that one), and Black for ground. Doesn't matter which black.
              There you go, a ps for your DC-DC PS to test indoors.
              Michael
                I would assume it would just be
                opus ATX
                12v >12V yellow (maybe off the a drive power connection?)
                ign > 12V yellow
                ground > ground
                  you beat me typing thanks!
                    That and a small battery would work great
                    Take my advice: Do not try to build a system that includes EVERY feature. Start with the basics, build it to a bug free state, and THEN add on.
                      opus ATX
                      ign > 12V yellow
                      ground > ground
                      After reading this thread needing to do the exact same thing (an easy way to perform in-house maintenance on the carpc without having to unplug the dc-dc powersupply each time), I came up with an Opus -> HD Molex connector. I even followed the shorting of the PSU "always-on" instructions. However, my DC-DC will not fire, and I get no CarPC power. Please reference the pictures below to see what I've done and if I totally screwed it up somewhere along the way.
                      Thanks (and yes I know, my fingers are in horrible shape, I had just finished doing yardwork and started in on the carpc stuff)
                      replicant
                      Audi A4 (flickr pics)
                        any help or suggestions on this would be awesome. thanks.
                        replicant
