Question about m2 and remote turn on for my amp?
  • Question about m2 and remote turn on for my amp?
    Ok on the m2, theres 2 pins, the remote and the ground (its all in one connector) so my amp doesnt have a ground (except for the ground to the car)
    so do i just connect the remote wire from the amp to it, and ignore the ground?
    also i should use a fuse right? what if i use the wiring from my hu? can i use the ground from the old wiring too?
    You only need to one wire, as they share the same ground. I tried this on mine but it fails to turn on my amp. I know I was doing it right as I used to have a M1 before this and that worked fine.. sadly this feature doesnt seem to work on my M2..
    CdR
    Follow me on Twitter
    http://www.FreeICE.co.uk
      cant u just link it to the ignition?
