24 AWG ignition wire
  • 24 AWG ignition wire
    would 24 AWG be too small to run to the ignition wire? i know the manual says 18 but just curious if i will have a problem using 24 AWG since I have some laying around.
    if not, could i just run 10 AWG instead since I have that also?
    24 is pretty small, but if it's just for the ignition signal to kick on your power supply, then you should be ok.
    If you have a multimeter, measure how much current is being drawn. If its more than one or two amps, use the 10 awg.
