Volt / Amps from Lillipt screen
  • Volt / Amps from Lillipt screen
    Hi , im using a Subaru WRX bolt in kit with toushcreen...
    But there's no computer right now. But i have installed the screen and using a computer (4 connector) plug to power it up. It works fine, but i have also included a fuse for the ACC wire (red) but im wondering how much AMPS i must use. Right now i have a 5 amps fuse.
    IS IT GOOD or do i need a lower one ??
    You should probably use a 1 or 2 amp fuse. They draw less then about an amp (on the order of .8 or so amps) for a total of about 10 watts of power.
    Michael
      only 1 amp !! wow... im way out of range !!! ok
      thanks for the advice !
        A good rule of thumb for fuses if 150% of current requirement. So a w amp draw should have about a 1.5 amp fuse. Going to low may cause the fuse to blow under normal operation, too high and you risk damage to your device from over amperage.
        Michael
          ok , ill try the 1 amp fuse and check out how it runs..
          anyways, in only using an xbox right now with the screen...
            I just used the fuse that Lilliput had in their "egg" - the little box that's in-line in the cig. lighter adapter that came with the screen. I believe it's a 2 amp.
            __________________________
            VIA SP13000 / M2-ATX 160W / 60 GB 2.5" HD / Lilliput 619GL / 512 MB RAM / BU-303 USB GPS / Panasonic Slim Slot-Load DVD-ROM/CD-RW Combo / Linksys WUSB54GP / Molex 3688 Case
