DSATX programming mode
  • DSATX programming mode
    hey, i can no longer get the DSATX into spitting out diagnostic information, actually trying all the commands the only thing it will do is @ (shutdown signal to computer)
    any ideas? do i need to open it up and do the jumpy thing to reset to factory defaults?
    95 Mazda Protege LX
    Worklog
    Overall [Project Dead] 0%
    2003 Nissan Altima
    [XXXXXXXX--] 80% Planning
    [XX--------] 20% FABRICATION/INSTALLATION
    Worklog
    I've had to do reset it a couple times....
    What jumpy thing?
    I just had to cut 12v to it a couple times and hook the branstem up to another PC (my laptop) to reset defaults.
    How about the Wiki?
      What jumpy thing?
      that did not work for me, tried that a few times earlier today
      jumpy thing - short the jumper at A, i think it was....would have to double check.
      95 Mazda Protege LX
      Worklog
      2003 Nissan Altima
      Worklog
        okies, i have had no luck what so ever in getting into programing mode( it use to work, that's how i set it up orig.)
        i get no diagnostic output(yes i am using all upercase letters)
        the only thing i can get to work is @ ( simulated power button press)
        other then that, nothing this is what i've done
        1) removed all power wires from dsatx
        2) shorted the reset jumper(tried this shutdown/powered up/unplugged no difference)
        3) unplugged the brainstem/serial cables
        all results return the same result - nothing
        95 Mazda Protege LX
        Worklog
        2003 Nissan Altima
        Worklog
          Then try D to reset to defaults, then try E
          It's an undocumented function that will enable writing to the DSATX.
          How about the Wiki?
            Its not Undocumented.. It's in the manual..
            http://www.mpegbox.com/pdf/DSATX_Manual.pdf
            MPEGBOX - Plexiglass Computer
            www.mpegbox.com
              Sneaky! You updated the manual!
              That's a good thing, though....
              How about the Wiki?
                found *part* of the problem
                for ****s and giggles, i took out the serial cable and plugged it into a cable tester. it has a few broken wires, upon closer examination, i found that 3 wires were not soldered in very well into the db9 connection. tommorow i'll see about locating a replacement cable, i will update post accordingly
                (fyi - TX works RX does not !)
                95 Mazda Protege LX
                Worklog
                2003 Nissan Altima
                Worklog
                  also, as a note, i'm still getting a dead battery from time to time, i really need the dsatx to FORCE OFF after x minutes. or X voltage....
                  95 Mazda Protege LX
                  Worklog
                  2003 Nissan Altima
                  Worklog
                    IT should do that by default.
                    Mine has a 300sec (5min) shutdown timer and a hard off after 1min.
                    How about the Wiki?
                      The DSATX should completly force off if ACC is low.
                      www.mpegbox.com
