Opus 120w
  • Opus 120w
    Just wondering if it was possible to connect the opus power to the radio harness ' 12v power and the ground to the radio harness' ground? Currently i have it connected to an 8ga fused power line and 8ga ground straight to the chasis. But i mite be moving me car pc to another location....
    2002 Mitsubishi Galant
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
    i think most people would tell you that the radio harness is insufficient for a pc power supply, the wiring isnt thick enough, heats up, melts, shorts, fire, dead
    no?
      Yeah, its not too safe to wire a carputer to the stock radio, you might be able to get away with it, but is it worth setting your car on fire? Your better off running a new wire to a fuse and then the battery.
