opus 150 stupid???
  • opus 150 stupid???
    is my opus stupid??? my GPS is always on and my CD drive even though my iginition is off, after a few days this is draining my battery, is my opus stupid? or is this normal? or is there a jumper i can change a setting?
    all fitted but its having a wobler!
    its normal the opus doesnt shut down the 5v line. Have a search and you will find a design to put a relay and some diods on the power supply that will cure this. I think you can send it back to opus and they can change the firmware that will shut the 5v down too.
    Visit my site V8 Scimitar
    SP13000, 300GB SATA HD, 1GB DDR. Opus 150, K301 screen, Cisco WIFI, AQmax GPS, RoadRunner and FreeDrive, Sony MEX-R5 head unit. 4 years installed and it just keeps running!
      try this
      99.9% complete.
      http://www.cardomain.com/ride/212327
        Subscribing...as this used to happend to me sometimes.
        Renault Megane...the OEM look
          same here. what's the diagram mean? sorry, I'm electrical-schematically challenged..
          Dr. Ron Paul for President 2008
          Hope for America - http://www.ronpaul2008.com
          Who is Ron Paul? - Why do we need Ron Paul?
          CarPC Newbs Start Here: All your questions answered, as if by E.S.P.
            the bit between the opus and the computer is the circuit you make. Its a relay and 3 diods. So long as the mobo is getting 12v the relay is closed and the sytem gets 5v. When the opus shuts the 12v down the relay drops out and the 5v line is cut. When you put your ignition on (ACC) the relay sees 12v again and closes the circuit reconecting the 5v as well as the opus switches the power on so it all boots up.
            So from a cold boot you get
            ACC on relay closes and power supply boots everything up.
            ACC off (you switch the ignition off) Relay stops seeing the ACC but still gets 12v from the opus, the opus stops seeing the ACC and shuts down or hibernates the pc. When the pc has shut down the opus shuts off the 12v power, the relay is now no longer getting 12v so it opens and disconects the 5v line.
            No more power drain and your battery stays charged.
              This doesnt happen with mine ......... may be the 5v line is on... but the cd drive and gps are off with the ignition.
              04 Corolla
              Modifications:
              Upgrading pc 99%
              Progress
                Is this fixed with the newer ones? I haven't hooked up my GPS/CD-ROM yet.
                Audio: 4 * Rainbow Audio Germs + Infinity Basslink / Case: iStarUSA S3 / CPU: C2D P8700 / MB: Jetway NC64-LF / SC: ASUS Xonar Essence STX / RAM: Crucial 2x1GB 1066MHz / HD: MTRON 2.5" 30GB / DVD: Panasonic UJ-815B / PSU: Opus 180w / LCD: Xenarc 700TSV
                  i'm albysure84 on im. usually on at night. i can explain it to you better
                  99.9% complete.
                    cheers matey
                    I dont use this forum much but it always come in handy!
                      Let us know if you come up with a solution.
                        mine is only a couple of months old so I doubt opus have changed anything in production. I don't think all motherboards leave the 5v live when switched of so maybe this is why some USB ports aren't live.
                          does the 250 pull this crap? or does anyone know yet
                          http://i25.photobucket.com/albums/c8.../positions.gif
                            Err.. I think this happened to me. Ended up draining my battery to the point of not starting . Is there a way to just turn off USB devices in the bios when not powered or something similar ???
                            Shotgun! - An Advanced CarPC Software Solution!
                              i keep having the same problem with my opus. many motherboards have a jumper to turn off the 5v to usb when the pc is off. Mine doesn't, but hopefully the rest will have better luck.
                              i was wondering, is there any way to connect a single toggle switch to atx connector. I'm pretty bad with power supplies so i dont have a clue as to which wires to connect it to however.
                              04 Corolla CARPC
                              Progress: 95% done (its never done)
                              http://www.mp3car.com/vbulletin/showthread.php?t=97518
