M1 Power Supply Ignition line
  • M1 Power Supply Ignition line
    Hello,
    Does anyone know if the igintion line for the M1 PSU actually needs to draw any power or is it just a signaling line?
    I'm going to connect + and - to the battery via a 10A fuse and possibly the ignition ine to the cigeratte lighter (if it is only used as a on / off signal for the M1).
    Does that sound reasonable?
    Cheers
    signal line only.
    and you should read some of the FAQ's on power wiring, etc... for instance, instead of running a ground wire to the - terminal of the battery, it's better if you ground the power supply to a nearby point on the chassis instead.
    But don't take it from me! here's a quote from a real, live newbie:
    Originally posted by Viscouse
    I am learning buttloads just by searching on this forum. I've learned 2 big things so far: 1-it's been done before, and 2-if it hasn't, there is a way to do it.
    eegeek.net
