problem with power opus power supply in the car
  • problem with power opus power supply in the car
    when I power on the cpu in the car, it starts to turn on then shut off. The green light on the opus 150 power supply blinks three time in a row. which tells me theres a problem with the voltage or power supply. Well I know it not the power supply, because I hooked the cpu on the desktop in my house, using dc-power 15amp power supply, and it worked normal. started up fine. In the car its a differant story, which has to be the voltage is out of range. how would I be able to correct this?
    https://www.facebook.com/hinnantdesign1
    Have you checked the voltage your supplying the opus with? If not get a meter and test it.
    Where are you currently running the supplies from and in what size cables?
    Make sure you have a good ground.
    Visit my site V8 Scimitar
    SP13000, 300GB SATA HD, 1GB DDR. Opus 150, K301 screen, Cisco WIFI, AQmax GPS, RoadRunner and FreeDrive, Sony MEX-R5 head unit. 4 years installed and it just keeps running!
      I found the problem with my carcpu. it was a bad ground. thanks for your help.
        No problem, Least it was something simple in the end.
