Powering LCD from cig lighter
  • Powering LCD from cig lighter
    Is it safe to keep my LCD (cartft.com CTF700) connected to the cigarette lighter during crank? I know there can be voltage spikes, and this particular LCD comes with a cigarette adapter plug. On their website, the specs for this monitor are "Power Input : 12-24VDC". Does this mean it can handle up to 24V? If so, this should be able to widthstand the spikes during crank, right? BTW, the monitor also maxes out at 900mA (back of the sticker says "12VDC ---- 900mA (Max)" )
    Oddly enough, the wall adapter it came with (European Plug), says "Output 12.0VDC ---- 1.25A"
    Monitor found here http://cartft.com/catalog/il/541
    This is how I am planning on powering mine.
    My cig lighter plug has a fuse in it, so I figured this would be fine. Plus the monitor doesn't actually come on until I hit the power button.
    Car-PC progress meter (researching and collecting hardware)
      Im also wondering the same thing
      im going to get a new lilliput screen and was going to just hardwire into the ACC with a fuse
      but when the car cranks doesnt the voltage drop and spike ???
      was going to go with a
      Carnetix CNX-P1900 Ver. 2.2 Dual Output 140 Watt 12V DC-DC Regulator
      to power both the screen and the laptop i use would that be a better option ??? i dont wanna wreck a nice screen with doing it wrong
        spikes when cranking and cig lighter power
        Honestly, if anything, your 12vdc voltage will drop during cranking. I honestly wouldn't worry about it. Whatever device will probably not even start to power up until you stop cranking anyway...
        dd
        2006 Mini S Convertible
        Woodbridge, VA
          dd
          I actually tried running my monitor off the 12v rail lof my m2-atx, and it seemed to work great. I will prob do this instead of running directly off the acc line ot the cig lighter.
            Car = DC
            Wall = AC
            big differences...
            Jan Bennett
              Originally posted by Red GTi VR6 View Post
              Car = DC
              Wall = AC
              big differences...
              Red, I think he was drawing attention to the fact that the apparent power rating (amps) for the display is lower than what's output from the AC converter. A concern that it may be getting too many amps.
              As compared to the 1.25 amps from the AC converter.
              http://gickr.com/results4/anim_5055e...a2b3b197c9.gif
              1990 RHD JDM 300ZX TT 2+2 5sp T-Top
              491RWHP / 18psi / 94 octane
                Well it may peak when it is turned on resulting in being fed more juice!
                Like old 74 TTL chips. When they first started, they used more power then microseconds after!
                1.9in x 2.9in -- 47mm x 73mm
                  so im wasting money on a Carnetix ?? or am i just being paranoid
                    I blew out a 'Super' LCD using the supplied cigarette lighter adapter in 1 week.
                    I now use only regulated 12v from my CarPC psu- no problems 6 months.
                    If I were you I'd play it safe and tap into the HD power connector.
                      for this hobby, you should invest in a voltmeter. measure the voltage during crank and normal running.
                      if you are interested in common practice- many people buy a regulated power supply to protect their investment in the screen. "better safe than sorry." but you'll hear that a lot of people don't use a power supply and they are fine. remember that the screen is one of the most expensive components.
                      personally- i use a power supply, because i need the 5volts anyway for the powered usb hub.
                        Yeah i wanna use the 5+ as well so i think ill go the PSU option...for Laptop screen and USB cartronix should do that with extra 3 outlet
                          Theres loads of posts on this, but this one is a cracker.
                          http://www.mp3car.com/vbulletin/show...70&postcount=4
                          I have my Lilli plugged into the lighter socket and its been fine so far, but if you wanted to regulate the power, then use the circuit as above.
                          '98 Peugeot 306
                          Project Status: I sold it ages ago!
                          ShutControl
                          The ultimate shutdown control software for laptops.
                            I wouldn't trust that 1 dollar chip to protect my 250 bucks screen.
                            Plus, when the engine isn't running, it doesn't do any good. Tap into the PSu 12 V and use it.
                            Y2K Accord Dell GX150
                            EmoRebellion is a SCAMMER
                              I don't have a PSU to power the 12 V. I suppose I'll just buy two POL devices, one for 5V and one for
                              12V
