M2-ATX Wont power on PC, fan turns every few seconds
  • M2-ATX Wont power on PC, fan turns every few seconds
    I am in the process of installing my first CarPC, I have a Commell LV-677 MB using a Core Duo 1.86GHz CPU and a SATA 2.5" 120GB HD. I am trying to use a M2-ATX 160watt DC-DC power supply.
    My problem is that when I finally got everything all hooked up I went and fired up the car and after a few seconds all that happens is the fan on the motherboard will spin about a full turn and then stop, about every 3-5 seconds this repeats and that is all I can get it too do, until I disconnect the power.
    At first I thought I wasnt getting a good ground, so I checked that and everything seemed good. I did some digging on the forums and found a ton of posts about the M1&2 having problems but couldnt find any issue like this...
    I took the PC back in the house and connected the m2-atx to a 350watt power supply and got the same results.
    Am I forgetting a step?, Is this another bad PS?, or is it just not enough power?
    Have you run a power calculator, to determine that you are not exceeding the wattage on each individual power line, 5v, 12v.
    Michael
      I came up with roughly 130watts, but I am not sure what the motherboards onboard video uses.
      The CPU is only supposed to be 31watts.
      This is what I have connected:
      Commell LV-677 MotherBoard,
      T2400 Core Duo 1.86GHz CPU,
      1 2.5" 120GB HD,
      1GB DDR2 memory.
      I really dont think I should be needing more then 160watt?
        List all your components. Have you tried removing some hardware to lower the power requirements, like DVD/CD drive, 1 stick of ram instead of using 2, and etc., for testing? Also, can the carputer power on directly from 350W power supply?
        CAR:06 350Z | LCD:Xenarc 700TSV | PS:M2-ATX | CPU:2.0GHz Turion 64 | MB:GA-K8N51GMF | RAM:1GB PC3500 DDR | HDD:WD 250GB SATA | USB1:Zoom 140M WiFi | USB2:iOne Scorpius Keyboard | USB3:Logitech Wingman | SERIAL:GPS BR-355
          1 2.5" 120GB HD,
          1GB DDR2 memory.
          I understand that you are under total wattage, but you have to figure out if you are exceeding the power available on EACH INDIVIDUAL POWER RAIL. While you may be under 160 watts, you might be drawing 100 on the 5 volt power rail, while the unit can only supply 50 watts. That will keep it from booting, or like you have, once the power is required, it won't boot, it will try, and spin the fan, but when the cpu starts to draw power, it shuts down, and over and over.
          Michael
            This is my exact current setup:
            Motherboard = Commell LV-677 [25 watts?]
            CPU = Intel Core Duo 1.86GHz (T2400) [31 watts]
            Video = Onboard Mobile Intel 950 Media graphics accelartor [10 watts?]
            Memory = 1 stick of 1GB DDR2 667MHz [10 watts?]
            HD = 1 120GB Seagate SATA [5 watts]
            Wireless = Asus Mini-PCI (Wireless G)
            thats it...
            Everything works perfectly fine when connected to a standard 350watt AC/DC power supply in the house.
              thats it...
              From what you have listed, should be only about 85W total. I am guessing a bad M2-ATX.
                You also are relying on total wattage. THAT IS INCORRECT.
                Here is the calcualtor I used. http://www.ohmygodmyarmfelloff.com/MP3Car/PSUpower.asp
                Next, I looked at the spec sheet for your SATA drive, and it requires 2.2 amps on the 12 volt line. That is almost 30 watts, not 5 watts. (http://www.seagate.com/docs/pdf/data...racudaata5.pdf)
                Your memeory stick is at least 16 watts, all on the 5 volts rail, which is about 3 amps.
                The processor is about 34 watts, and I believe it is on the 3.3 rail, though it could be on the 5v rail. Assuming 3.3, that is 10 amps, and 5 volt would be 7 amps.
                An MB with on board devices use about 1.5 amp on the 3.3, 1amp on 5 volts, and .5 on 12 volts.
                These numbers are the best I could find, and might be higher or lower, but will be a start.
                Here are the specs for the M2, http://resources.mini-box.com/online...etype%3Apdf%22
                Each rail has a max of 8 amps, 3.3, 5, and 12 volts.
                The 12 volt rail seems fine, since it has 8 amps, and you are using about 3 amps. 3x12=36
                Now, lets look at the 3 volt, using the worse case scenario,
                the MB, 1.5 amps and the processor 10amps. That is 11.5, over the amperage of the M2. 11.5x3.3=38
                Now, lets look at the 5v line, assuming the worse case scenario
                The MB is 1amp, memory 3amps, CPU 7amps. Again, you are over the amps rating of the 5 volt rail. 11x5=55
                Even if the CPU voltage is split, you are taxing both the 3.3 and 5v rails. If it uses only one of them, you are DEFINITELY over on either rail.
                NOTICE that in any situation, you are under 160 watts. 55+38+36=129, and that is assuming the absolute worse case scenario on BOTH the 3.3 and 5 volt rails AT THE SAME TIME.
                That is why your system won't start.
                Is there a reason you did not follow my advice and run a power calculator on your system and see if you exceeded the amperage of a single rail?
                Michael
                  Michael
                  1) The power calculator you posted is missing way too many major variables (cpu, HDD, and etc.) to be truely helpful.
                  2) Intel says cpu uses 31W.
                  http://www.intel.com/products/proces...eduo/index.htm (Click on View processor numberΔ details link)
                  3) Your Seagate PDF example is for desktop 3.5" SATA harddrive. He's actually using a 2.5" SATA laptop drive. Wattage for this drive seems to be 0.28W (standby) - 2.2W (seek).
                  http://eshop.macsales.com/item/Seagate/ST9120821AS/
                  4) DDR2 uses 1.8V compare with 2.5V in DDR. Thus, it should be less than DDR's 10W rating, around 7.2W. Not sure where you are getting 16W from.
                  http://carpc.kyferez.com/Tools/PSUWattageCalculator.php
                  A "working" M2-ATX should power his system. My carputer should be more taxing on the M2-ATX than his setup.
                    The M2-ATX fried my motherboard!
                    So I take my CarPC into the house, and got the same problem when I connected the M2 to a standard AC/DC power supply. So finally I decided to just fire it back up on just the standard 350watt PSU I had it on when I initially set everything up. The first thing I get is beep codes! I quickly shut off the power supply, and check all my connections everything looked good so I try turning the PC back on. Now everything powers on, (HD, CPU fan) but it WONT POST!?!
                    I tried disconnecting the memory and turning it on without memory to see if I could atleast get some beep codes and I got nothing!
                    So now I have a bad PSU and a bad $300 MB...
                    This project is becomming such a headache
                      I also have a LV-677.
                      I used a dc converter M2-ATX and when i power it( the M2) with above 15 volts the mobo does not POST.But it starts ok when i give below 15 volts.
                      It is not a problem of the M2-ATX because i used a second and the same happened.
                      I also used my own digital power supply and the same problem.
                      But then i used this dc-dc converter
                      http://linitx.com/product_info.php?c...roducts_id=428
                      and i had no problem at all.
                      What is happening?
                      The above power supply and the M2-ATx have about the same specifications.
                        Yeah, im running more than that off of an m2 also without problem. What size power wire are you using from the battery to the m2? Ive noticed if you don't use wire gauge that can carry at least 20 amps the m2 won't fire. This happened to me while bench testing. I was running the m2 and all my carPC2 parts off of a single 12v rail on a standard ATX power supply. Didn't have enoughh amps to get her to fire. Hooked it up to the car battery and it works perfect. Also make sure your power switch is hooked up to the m2 correctly. If the switch is wired wrong ive seen this happen.
                        Last but not least, take out all jumpers for the startup/shutdown controller. This will make it a standard 'dumb' power supply. You just need to hook up positive and neg. then the ignition 'switched' wire is not used in this power scheme. This should fire your hardware (may need a manual switch) no matter how large your wiring is, although it will get very hot if its a smaller gauge. Anyway if you pull all jumpers, juice it and still no luck then I would say you have a bad unit. Although I own 2 of these m2's and they really are a rock solid power supply. Almost all of the time something is not working its due to human error. Most of the time improper wiring. I had my switch wired wrong on my 2nd m2 and it wouldn't fire. Finnaly realized it, fixed it and the m2 worked great ever since. Double check all connections, and let me know if any of these suggestions work.
                          I also had an M2-ATX go on me and took my MB, HDD, Keyboard, DVD drive, and GPS along for the ride. Lets hope you're not in the same whole. For me, carputer was working fine for about 2 weeks, and one day, it suddenly without warning blew. After replacing everything with the exact same hardware, knock on wood, it's been running w/o any problems for 3 months, but in the back of my mine, I am still afraid.
                          There seems to be way too many people having problems with M2-ATX. Just do a search. The quality doesn't seem to be great on these things. My conversation with an employee at mp3car.com store only further my suspicion. Next time, going with something more expensive. Guess, old saying is correct "Trying to save a few bucks will only get you in trouble down the line."
                            same problem here.
                            Hi djjerdog
                            I Have the same setup as you,And the same problem.
                            The problem is the m2-atx.It dont work with the commwell LV-677.
                            Dont ask me why. i dont know...
                            It worked fine with a normal pc powersupply.
                            I now have a opus powersuply,No problem anymore
                            I give up on the trying the get m2-atx the work with the comwell mobo
                            Try many time's to mail the manifactory of m2-atx
                            Only 1 reply. Sent it back ,you get your money back.
                            See My topic. http://www.mp3car.com/vbulletin/showthread.php?t=79862
                            Good luck trying the get it to work.
                            If you do ,please mail me,
                            Because i bought a pc-case that fits my Mobo and m2-atx in one.
                            I now drilled a hole for the opus powercabel.
                            P.s commwell makes a AC/DC motherboard of the LV-677
                              While there have been reports of M2 going, and taking the whole system, I think in some cases, and this might be one of them, that the owner overloaded the M2 and it blew.
                              Michael
