Power Supply or a dc regulator?
  • Power Supply or a dc regulator?
    Hello everyone,
    I am thinking of buying a dell sx270 (small form factor, external PS). Now, is it better to buy a costly dc-dc power supply (The nicer ones) or hacking apart the ext. p/s and run it directly to the battery? I have read other post, that they have done this. Mostly because they claim the sx270 mobo has a built-in regulator. Now here is my idea, I want to use a dc 12v regulator ( like this one ) Is this a good idea? If so, they make 5V regulators too. Can I use those to power usb hubs, etc... I am not a power expert, The items i found maybe the wrong ones. So any help is great! BTW I have a good size stereo system, sucking up alot of power. (4000w max avg 2000w RMS)
    thats not a regulator!
      I must be mis-lead by the title? It said it has a built-in regulator? Can you explain a little more please?
        Did I put this question in the wrong forum?
          Yep, you've been misled. That is not suitable for powering a computer, not even close.
            I ahh.. think its a volt meter :
              The computer (sx270) just needs 12v regulated. It doesn't really need a power supply. Does anyone have an idea of where to get what i'm looking for? I have done the searches, but it's useless if I don't know what i'm looking for.
                How about a voltage Stabilizer?
                Could this work?
                Or maybe a isolator for a three battery setup? One batt for the engine, One batt for the audio system, and One batt for the truckputer. All will be charged by the alt. So no batts will affect each other. (current draw)
                  I'd check to see how many amps that's capable of regulating before you buy.
                  Frankly, for a vehiclePC setup, there are far simpler solutions that don't require a second battery or any other major mods to the vehicle electrical system.
                  Unless you're building a high-end show car with assloads of electrical components (hydraulic pumps, actuators, 80 gazillion watts of audio, robotic arms, welding equipment, industrial HVAC equipment, etc.), you're not going to need all that battery power, plain and simple.
                  How about the Wiki?
                    You do know what you are looking for, it is in the thread title. You need a regulator.
                    If you had searched in the store on this very site you might have found this : http://store.mp3car.com/SearchResults.asp?Cat=11
                    Now you are spoilt for choice.
                      I see now, I almost thought I was crazy. Hell maybe I am! Anyways thank you. I was so busy searching google and these forums, i forgot about the Mp3car store.
                        dell sx270
                        How is with your AC-adaptor from dell?
                        How much is out. Volt?
                        How much ampar?
                        How much Watt?
                        How see out contacten ?
                        Is the two cabel. + and - ?
                          Sanity is soooooo overrated..
                          How about the Wiki?
                            I just bought a sx260 1.8 Celeron for $133 (ebay) shipped. Duno about the sx270 from dell? The pc takes 12v @ 12.5 amps and 150w. Sorry Hamid_sw, don't understand last questions.
                            Now after i just bought it, is when i think of the video. Cause my datalux monitors are wierd, They don't work with every vga card. Crap, I my have to resale the unit if that's the case.
                              hi dvsmex
                              sorry for bad english.
                              last the question is how see out kontaktn and how many cables is coupled until cavity
                              if this have just 2 cabel in the contact
                              maby you can use samthing like that.
                              http://www.clasohlson.se/?AFP=store/...166E209A885509
                              http://www.elfa.se/elfa-bin/setpage....0&dok=4662.htm
                              http://www.netonnet.se/index.asp?iid...100C1749401861
                              if you have more cabel in det contact out from your AC-adapter (dell usually have 3 kabel, 12v, 5v, and zero) you muste have different.
