Powered Portable CarPC with laptop battery?
  • Powered Portable CarPC with laptop battery?
    I am planning to put together a portable carpc/media player and wondering if I can use the laptop battery to power my carpc. Will there be any flutuation in current if I use the cigarette adapter to charge the laptop battery as well as power supply to the carpc? Any comment is greatly appreciated.
    a laptop battery is designed to power.. get this, a laptop
    if your not using the laptop, it probably wouldnt run for very long, unless you have a very low power carpc
    and how would you charge the battery safely through the lighter socket? you'd need a way to not overcharge it
      Yea, i would strongly advise against it, if i'm not mistaken, the computer regulates a good amount of what the battery does, in terms of when to charge, when to stop charging...and, you're going to run into a whole mess of problems that way.
        well, i agree laptops can charge batteries, because they have the charging equipment..
        if hes using desktop pc equipment, then i highly doubt it would be able to charge anything, or regulate the battery well at all
        (OP didnt say if he was using desktop equipment or laptop)
