Carnetix powering laptop
  • Carnetix powering laptop
    I have an IBM T23 or T30 laptop that I would like to use in my carputer installation. I'm leaning twords using the carnetix p1900 because it's capable of suppling a 12v to my external hd and a 5v for an external sound card, plus the laptop itself.
    My dillema is that the laptop takes a 16v input and the primary output on the carnetix is 18v. I don't know how much harm 2 extra volts would do but it probably wouldn't be very healthy. Is there a way I can drop this down two volts or am I going about this the completely wrong way?
    I've searched but it just leads me to dead ends. Thanks for the help.
    I'm pretty certain that the extra 2v would be bad.
    If laptop requires 16v, you need to feed it 16v.
    You might try a vehicle adapter for your make.model laptop. You won't have the startup/shutdown capability, but there are other solutions for that, as well.
    How about the Wiki?
