Power Supply problems
  • Power Supply problems
    Hi,
    I hope you guys can help me. I have built a power supply based on the MAX787 IC. You can see it here http://www.jarcom.com/inmotion/power.htm
    Now, instead of using a 50uH inductor (which I could not find), I used a 47uH instead (with a 10% tolerance) thinking that this should be ok.
    When I plugged it in with no load it was ok abut when I connected it to the computer, the inductor burned up quite quickly. I tested what current the PC is drawing and it is only about 2.5A or a little less -- this is well within the 5A load limit.
    Do you guys have any idea's before I do get another inductor and try again.
    Thanks a lot,
    c-dawg
    what is the amp rating on the inductor? should be atleast 5amps min
    also check for shorts on the board
    Mastero
      Thanks!
      The current for that inductor was < 0.1A !!
      No wonder it turned into fried silcon!
      I have order a 7A inductor but it has to ship to me and it will take a week ok well -- I guess I will have to wait!
      Thanks again,
      C-Dawg
