Opus 150 problem coming back from hibernation...
  • Opus 150 problem coming back from hibernation...
    Here's a quick rundown.
    Bought the system used w/ the PSU outside of the CarPC package. I have since purchased a new case and integrated everything into one case for a clean package and neatness of installation. Also this will allow me to easily remove the PC in/out of the car when needed for updates, fixes, etc.
    After I put my PC back together, everything seemed fine as the system booted up, powered up normal and does run. It was running for the past three hours with no problems.
    However, after testing the hibernation aspect to ensure that that was still working, I found that it would hibernate, but won't come back out of hibernation once the acc line gets hot. It would fire up like it normally does, then a click, that's it. The power LED on the PC stays on, but nothing.
    I have read that certain apps get hung up and that can cause the system not to hibernate properly. I am still searching on that issue.
    In any case, I found this thread:
    http://www.mp3car.com/vbulletin/show...5&postcount=12
    but don't know what to make of it.
    I had to disassemble the Opus 150 casing to get it to fit into the new C137 case. Looking at the OEM Opus case, it doesn't look like the coil was touching the casing at all.
    Can anyone please shed some light on this matter?
    Thanks.
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
    Im having the same issue, but with a OPUS 320
    1X Ainol Novo Flame Tab
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1X 7 inch motorized Screen
    1x Win 7 PC
