DSATX killed my battery yet again :(
  • DSATX killed my battery yet again :(
    I posted this on Mpegbox.com about a month ago and never recieved an answer. So maybe someone here can help me. I went out to my car to start today and it had a dead battery again, I want to keep my carputer in standby mode when the car is off(yes know about hibernate but thats not what I want for many reasons). I want the computer to keep the 5vsb alive for as long as possible. however I also want to be able to start my car too. So I wanted the DSATX to monitor my battery voltage then shutdown the 5vsb ONLY if my car's battery is about to die for example if battery drops below 11 volts. Is this mode possible I do have the brainstem, or would it require a firmware update.
    It's nearly an impossible mission to protect the battery only based on monitoring the voltage under this situation.
    The discharge current could be less than 1A while the computer is in hibernate mode, and the battery was already dead when the voltage enen drops below 12V at this low discharge current.
      http://mpegbox.com/pdf/DSATX_Manual.pdf
      Page 4,
      "P2* Low Voltage Adj: In Basic Mode, clockwise rotation raises the low voltage threshold (10V-12V)"
        what you want to do is impossible...sorry to say that.. standby will kill you battery eventually..very early and in a few hours.. no 100% protection against thet..if you insist on doing that..then get your self a second battery and a battery isolator..then leave your pc in standby.
          My battery has a 120-minute Reserve Capacity. That's a 120-minutes of a 25A draw before the voltage drops under 10.5V. Call it 2 hours at at 11V, that's 550W-Hr. Even if my computer consumes 10W on standby (it shouldn't, I think), that should mean the battery can sustain it for 55 hours. Overnight should be easy. No? What am I not realizing here?
          Elantra GT 1.2GHz Duron, RoadRunner & LSX Void 3.2. Status: Stable...
            it is not a matter of overnight..not starting your car is risky..it is something you don't want to have on your mind all the time...hell life has many other problems..no need to add even more.. forget about capacity and stuff, you will never be able to calculate your time allawance..(this also changes when your battery gets older..) do your self a favour and use hibernate/get another battery
              I use an M2 ATX and Standby. My battery is fairly new. I have left the car idle for as much as 80 hours, and the car started fine.
              No 2nd batttery is needed. As for doing it with YOUR system (with an unknown power draw) and the DSATX it should be possible.
              Michael
                The way I have the DSATX setup it should do voltage monitoring, I have read and re-read the manual several times. However the DSATX is just not working properly. My computer has been left on overnight a few times due to windows not really going into standby. The way the manual reads the DSATX should cut power to computer after a predefined voltage threshold is reached, however in practice it does not. I have tested the battery voltage with a multimeter right after one of these incidents and it is around 6-7 volts while the DSATX is set to shutoff after 11.4 volts. Is this yet another DSATX firmware issue? or is the feature on the DSATX just broken???
                  It is hard to say. When the voltage is 6 or 7 volts, how do you know that the DSATX hasn't shut down already. Maybe it shut down at 11volts, but your battery dropped much lower for other reasons.
                  This might mean that you need to leave the computer in standby, and then every hour or half hour, check the voltage of the car battery, and when it drops below 11, check the DSATX to see if it shutdown (I would probably just turn the key to the run position, with out starting, and see if the computer comes back from standby, or if it reboots). How do you know that you have set it correctly?
                  Michael
                    1. When did you buy your DSATX?
                    2. What does the sticker on the back say?
                    3. Have you used the brainstem serial adapter to load any custom settings in?
                    4. Have you tried putting the p2 pot in the center at 11 volts and seeing if it doesn't kill the battery?
                    5. Did you try loading factory defaults with the brainstem?
                    MPEGBOX - Plexiglass Computer
                    www.mpegbox.com
                      6. If you disabled sleep mode, or messed with the 5vsb off enable, then it won't do what you want. I need to add the mode where it will still monitor the voltage and pull the plug only after it drops below the cut off voltage.
                      www.mpegbox.com
                        Hi,
                        Just a thought.... Are you sure your OS isn't freezing/locking up? If I understand the low voltage cutoff correctly -- after it notes its hit the low voltage it sends a shutdown signal to the computer once the computer has shutdown it then goes into a "sleep mode". So if your computer hangs, it never shutsdown - thus using full power all the time.
                        Infact, as I think about it -- are you sure it goes into standby mode correctly? It seems odd that your battery dies from being in standby mode is less than 8 - 10 hours (my WAG based on you saying this happens "over nite").
                        Nasa
                          Originally posted by nasa View Post
                          Hi,
                          Nasa
                          There is a 90 second timeout that pulls the plug if the computer doesn't shutdown in 90 seconds. This will never happen.
                          I think he is using some of the advanced features and they are not doing what he really wants. I am working on this..
                          Jeff
                          www.mpegbox.com
                            I know my computer never turned off because I went to start my car and I heard the fans on my computer running the computer was hung of course my car wouldnt start after that.
                            Jeff,
                            I did disable sleep mode, and experimented with the 5vsb off enable, But that is the only way I can get the dsatx to power my computer off and on reliably. If I use the default values it won't turn my pc on but it will turn it off. It used to work correctly, not sure what happened to it maybe corrupted firmware? I'm not really sure what the sticker on the back of my dsatx says since that would require my to pull apart my carputer to see it.... It is about 5-6 months old here are some values I pulled from the brainstem if that helps P_VERSION=0109 E_VERSION=0109. I really need the sleep mode, and 5vsb to work so I get my carputer to do what I wanted it to do. Is there there an ETA for that updated firmware? and would it be possible for me to flash it myself or do I need to send it to you (I do alot of work in embedded systems).
                            Ps. The DSATX completely loses it's brains after the voltage gets very low I have to unplug power to it just so I can use the brain stem to restore the factory defaults.
                              Just a suggestion, but are you sure that there is nothing in your car draining the battery?? I've had issues with bad wiring that were causing small shorts that were draining my battery. Just do an analisys of your battery usage with/without your PC.
                              08 Lincoln Navigator www.mobiteklink.com
