Not Starting In Cold Temps
  • Not Starting In Cold Temps
    Hey Everyone,
    Well its been pretty cold here for the past 2 weeks around 12F-25F
    The computer is not starting up at all, just a blank screen but after driving for 15-20mins the computer starts up.
    I am using a Opus 150
    Any ideas? I never had these problems in the past few years.
    -Devin
    harddrive. many threads on this. some are very recent, meaning yesterday.
    1.9in x 2.9in -- 47mm x 73mm
      I do not think the hard drive is the issue because the OPUS does not even start to turn on so the hard drive does not even spin.
        how do you know that the opus wont turn on? you use a multimeter?
          Agree that it's the hard drive, though you should be able to see it run through the post since that's from the bios not the hard drive. I'm having similar issues, but see the post each time.
            It's getting to -20C in Virginia?
              No, but anytime my car sits overnight when the temp falls below freezing it takes quite a while for my carputer to boot. As I mentioned, it goes through the post and then nothing for ten to fifteen minutes until the hard drive warms from the heat of the processor. I never had this issue until I installed a new Maxtor 300gig hard drive a month or two ago. I'm assuming that there's some fluid in the newer drives that doesn't like the cold.
                It is not getting to post, the OPUS does not even acknowledge the signal from the ignition wire in the car
                  The poor little electrons are frozen solid and can't move down the wire
                  Check the signal voltage to the OPUS, and your 12V to the power supply. It sounds like it is a bad connection, or for some reason you are not getting enough voltage to fire up the OPUS.
                    my problem is similar, Im using an m2-atx. but my problem isnt from the hard drive, its from the bios resetting itself overnight when it is cold. I am guessing that the battery just cannot maintain enough voltage or current hen it is frozen, and my temps up here in maine are often well below zero F.
                    I am wondering if I hook up two batteries in parrallel if the added current would be enough to survive through a sub zero night, or if I would just burnut the motherboard in the proccess. lol
                    any thoughts?
                    .______
                    / '__|__\____ VW CarPC project
                    \(o)_____(o)/ Full Spead Ahead!
                    Props to my Sponsor, Summit Adventure Systems Mobile Climbing Walls
                    www.summitadventuresystems.com
                      I was having a similar problem. I took my car pc inside and tried to start it up in a warmer environment, but it still take forever to boot. Is there anything I can do about it?
                        AngryMan, have you tried replacing the battery on the motherboard with a new one? Might try a small 12v low amperage light bulb placed next to the battery that won't draw so much power that it kills the car battery and use it for a heat source. Just a thought.
                          You can get a replacement battery from a "computer" store. They are essentially 2 AA batteries and are made for early motherboards where you couldn't replace the cmos battery. If that don't survive........I dunno what will.
                          I'm just north of you in Nova Scotia, I hear ya about the cold. My cmos bat was doing the same thing, the temps have let up a bit here and the problem is gone, for now. I'm going to try a new 2032 battery first as mine is a couple years old.......
                          Cheers
                          BJ
