Accessory Power Supply
  • Accessory Power Supply
    I'm in the process of installing a notebook for use as a carpc, and it is being powered by an auto/air power adapter. That all works great. In order to add a few goodies (GPS Receiver, bluetooth, etc) I want to put a powered USB hub in, and I also want to put a slimline DVD drive in the dash.
    I'm searching for suggestions on a power supply I could put in the dash basically to power those two items. The notebook is installed behind the back seat. I certainly want to get a power supply that is sufficient to do the job and has some room to grow, but I also don't want to go overboard; it's not going to power the whole system, just a couple accessories. Thanks for any input!
    Here are a couple options: http://store.mp3car.com/SearchResults.asp?Cat=10
    How about the Wiki?
      Perfect. I was just looking at the OPUS 15 watt and it seems to be just what I'm looking for. I just need to find a nice little enclosure of some kind to mount it in and I'll be in business. Thanks!
        hit up a Frys or a Radio Shack and look for a project box. Should be the solution you're looking for for something to mount the 15 in.
        Jan Bennett
