Can two USB hubs be powered off of one Molex connector?
  • Can two USB hubs be powered off of one Molex connector?
    Hi All,
    The focus of the question is around physical wiring...I believe I don't draw enough on either hub to go beyond the +5v 3amp limit, but I'm wondering if there's anything bad that would / could happen if I tap the +5v line on the Molex twice, once to each hub..like current flowing in some bad way. I'm 'dangerous' as I don't have an electronics background but have hacked my way around quite a bit without killing myself yet ;-) This is probably pretty basic question, I just don't know.
    TIA,
    Per
    Originally posted by S4Per View Post
    Hi All,
    TIA,
    Per
    Nope, no problem, assuming the wiring is thick enough to handle the amperage, which should not be an issue.
    Michael
      thank you sir!
