PSUMoni, P2140 and Windows 7
  • PSUMoni, P2140 and Windows 7
    Does anyone have this installed so it works?
    I have firmware 1.8.3 installed and PSUMoni v1.8.3, tried installing with the compability mode and all and for some reason it always says that the USB is not connected.
    Windows 7 32bit
    Please help.
    Thank you!
    2005 Majestic Blue Nissan Altima | 7" xenarc | P4 2.0 | M2-ATX | Holux GPS | Bluetooth | Wifi | Road Runner |
    I had the same issue and ended up going back to XP. I am hoping they come out with a windows 7 version so i can upgrade
    2009 Volkswagon Tiguan
    Custom Built Carpc, Only way to go
      Here's another vote for windows 7. I need windows 7 64 bit drivers, etc. Intel mac OS X would also be OK, as I'm actually using it for a mac mini anyway.
        Try this everyone that get the message "USB not connected" on Windows 7
        1. In the device manager, right-click on psumoni 2140 device.
        2. choose properties
        3. choose the power managment tab
        4. only the "allow this device to wake up the computer" should be selected
        Good luck!
        /Bruno
        www.shutterspeed.se
          Has anyone tried Bruno's suggestion?
            It's odd they can't be bothered with supporting Win 7. It has advantages for a multi-processor car pc that don't exist in XP. Buying XP just to get this little piece of software to work is a waste.
              go to this thread:
              http://www.mp3car.com/vbulletin/cnx-...ml#post1389917
              This is the app/drivers I use in my Win7 setup, it also includes drivers for X64. You can also run PSUnomi from the app.
              TruckPC - gutted, being used for test setup
              BoatPC - All in 1 in cuddy, N7 using VNC on dash, RR
              BlazerPC - Nexus 7 with Timur's USBROM
                does this work on win 7 home premium? or do i have to upgrade to ultimate?
                i'm using 64 bit and it wont launch PSUmoni at all , keeps saying PSUmoni has stopped working when i try to launch.
                  my post above solved my problems on my Win7 home premium install.
                    Have you tried it on x64?
                    1999 Mercury Grand Marquis GS with: ASRock E350M1 w/4GB RAM, 80GB Intel SSD, Opus DCX3.120, Visteon HD Radio + HDR-USB, PL-18N wifi, OBDLink Scan Tool, BTA6210 BT, BU-353, Win 7 Ultimate, CF 4.0, Alpine MRP-F240 + MRP-T220, RF Punch 1572s, Kicker 8" Comp.
                      ditto that
                      DaveDog, have you tried it on a x64?
                      I was able to install the program you mentioned, however, I'm still unable to simply launch PSUmoni.
                      'PSUmoni has stopped working' is the error I keep getting running on Win 7 home premium 64 bit
                        Originally posted by MachinasDei View Post
                        ditto that
                        Didn't you just post over at CF that Carnetix is going to release a new beta for all Win 7 operating systems, and that all Carnetix Windows 7 drivers are experimental?
                          yep, but if people are already running PSUmoni on windows 7, it SHOULD work.
                          that seen and said, it should work am I right?
                            I haven't seen any posts on people with x64 getting it to work. Only x86 installs have it working. So if you switch to x86, I guess it will work.
                              yeah you are correct about that, thats why im posting about wanting to get 64 bit to work.
                              i'm considering changing to 32 now...
                              but i have a bit of promise after a little experimentation, using davedog's post and download (for x64)
                              it seems to control the p2140 and you toggle some settings when the usb is connected....-this works even when PSUmoni fails.
                              so i can sucessfully test it with my ignition switch and send it to standby and it brings it back up.
                              now i just have to figure out how to set win 7 to hibernate and come back.
