P2140 Issues, Sleep mode problems
  • P2140 Issues, Sleep mode problems
    I have windows 7, Centrafuse 3.1 (running as shell) P2140 powering a custom PC with a PICO150 power supply. My issue is that it will put it in sleep mode sometimes and then stop and just cut power. I have the updated drivers and software and i can connect. Is it possible this is caused by running Centrafuse as a shell or a issue with the software. Also does the Psunami software need to be running in order for it too be put in sleep mode.
    At this point i am thinking of switching to the m3 ATX power supply and just take that P2140 out and sell it.
    2009 Volkswagon Tiguan
    Custom Built Carpc, Only way to go
    Did you manage to fix your problem?
    If not check out these posts it may help you track down the problem.
    P2140 - Drawing to much power in Standby
    p2140 cuts power before completing standby
