Startup Delay
  • Startup Delay
    I know you can change the time on the "anti thump" (DLYon) but can you change the time the unit sends the power switch "pulse" time? I have a Fit-pc2 that i soldered power switch header onto but the unit wil only accept a "pulse" after about 3 seconds of having +12 applied. I need to be able to change the "pulse" time or the length of the "pulse". Can both or either of those be changed? If not I guess I will have to add a mometary relay to the DLYon.
    Thanks for any help,
    Dave
    Edit.. I found this http://www.carnetix.com/P2140/P2140TimingSequence.png and it talks about the ACPI Delay and Duration sliders and I think those are what i am looking for. Is that correct?
