wireing
  • wireing
    how would i wire the cnx-p2140 to my ZOTAC H55ITX-A-E motherboard?
    "How do I wire it" is pretty broad.
    Here is the link to the owners manual for it: http://carnetix.com/installation/P21...anual_V1_2.pdf
    I would suggest if you start from there, you should be able to narrow down the specific questions that you can't find the answers to or don't understand which will make it easier for members to help you.
      you can't. the carnetix is a single output(technically dual output), non-atx compliant power supply. your zotac board is a atx-compliant board, and so you require a intelligent dc-dc atx power supply.
      next project? subaru brz
      carpc undecided
