m2 powersupply and asus itx mobo - extra pins on connector?
  • m2 powersupply and asus itx mobo - extra pins on connector?
    so on the mobo where you plug the power connector in it has 4 more pins than what come off of the m2 power supply.
    is this normal? i just connect the cable the only way it can connect and the 4 remaining pins on the connector on the mobo just remain unplugged?
    just want to make sure and not damage anything.
    TIA
    Heath
    First Carputer in progress.....
    Yeah, this is normal. Your mobo has a 24-pin port on it, and the M2 only has a 20 pin cable. The connector should only fit in one way, and then leave the other 4 pins un-connected. It should still work, if it doesn't, well then you will need to find a 24-pin psu (but you wont damage anything finding out).
    -James
    Car: 2004 GTI VR6 24v Turbo 2.8L, GT35R, 630cc, Unitronic, Bosch 044, etc, etc..
    Main PC:i7 [email protected], 6GB DDR3, MSI X-58 Pro-E, Win 7 x64 RTM, Scythe Mugen2, 128GB G.Skill Falcon, 2x ATI4850 512MB Crossfire, Auzentech X-Fi Forte, Grado Labs SR-80
      thanks for the reply.
      makes me feel better there wont be a small explosion when I turn the unit on
      Heath
        You can also get a 20-to-24pin adapter.
        It's a less pricey option than a new PSU.
        How about the Wiki?
