M2-ATX jumper settings
  • M2-ATX jumper settings
    whats up guys, I recently bought a carPc setup from an individual online and I finally got it installed. My only issue is that I cant get the power settings right. I believe it has a combination of 1 or 2 issues, first as far as startup it boots up perfectly, Im running Centrafuse 3.0 on XP by the way. But when it comes to shutdown, I shut the car off and it goes immediately to standby, and eventually shuts off. After 1 min or more, if I restart the car, it reboots all over, and does not resume from standby or hibernation. If I manually select standby or hibernate the PC will go into the selected mode, but start right back up again! But if I select Turn off, it shuts down and does not comeback on unless I start the car again. Does this have anything to do with the J10 jumper settings? I looked at the M2-ATX manual but its not making since to me as far as the settings and the ABCD diagram, anybody know how to set this?
    anyone have an answer for him? i for the the life of me cant get hibernation to work either. runs fine when i turn the car off the pc shuts down even though i have the hibernation settings correct in the power options. mode 1 on m2atx jumper to the far left i believe.
    CarPc Progress
    Planning 100%
    Assembly & Fabwork 80%
    Installation 95%
    Bugs worked out 45%
      Right click the desktop and select Properties, go to Screen Saver, set Power Button to hibernate.
        Do this. The jumpers on the power supply are only for setting how long the M2-ATX stays on before initiating its shut down. And how long it waits before shutting off hard.
        Ampie Case
        256 MB DDR2 PC5400
        Xenarc 700TSV - VGA Monitor
        Intel D945GCLF Motherboard
        M2-ATX-HV
        2005 Honda Civic
          ok its been an few months since the install and having this issue. It appears to be an issue with the atom 330 processor I'm using in combination with windows 7. MOST of the time the system shuts down properly, hibernates as its supposed to, then resumes at ignition. I would say 1 out of 7 start ups the system does not come out of hibernation properly. It would say system did not shutdown properly or whatnot, which is very irrating when youre hoping for a smooth quick startup each time. I'm still trying to figure out the cause but its hard to tell, anyone have a similar setup with this issue?
            On my setup, all the power options are set to hibernate,
              Most likely a driver is causing Windows to fail to hibernate. Usually you'll see a dialog pop up showing the reason, then after the PSU times out it will cut the power. There should also be errors in the event log.
                Centrafuse is the front end im using, it has a log i beleive, would that be the event log to check?
                  No. Administrative Tools -> Event Viewer. Should be under critical or error.
                    I checked the event log and it said the kernal power task had a critical error. error 41, task 63 i have no clue what this means. Would antiviris cause the system to freeze or shutdown? I watched the system go into hibernation and the screen went blank immediately and did not show the system slowly preparing to hibernate.... im still stumped
                      Are you sure it's not "Power Management"? Error 0x41 doesn't give me any ideas either. Is that the bugcheck code? If it was power management, that usually means a driver can't hibernate. Try unplugging as many USB devices as you can. The error may or may not be from a driver though.
                        idk either, I just know its Kernal/power related, Event ID is 41, error 63. it also has 3 other errors to go along with it each time it happens, I'll post all the info up later today.
                          Double-click the entry and it should a general description. Above that are 2 tabs (General, Details). Click Details. That should have BugcheckCode under EventData.
                          You can look that code up here...
                          http://msdn.microsoft.com/en-us/libr...(v=VS.85).aspx
                            Hibernation works perfectly fine with my system on an M2-ATX. The M2 jumpers only change when the simulated "power button push" will be, and when the hardoff (power completely cut).
                            Hibernation should be managed through the OS power settings. Your MB also has to support this function. The PSU is rarely cause for failure with these settings
                              I'm reviving an old thread, but I just ran into the same problem as the original post. Any solutions out there? I've been searching and troubleshooting for a couple days and have singled out the M2-ATX as the problem. When I hit the manual PC power button, it hibernates right away, when I use the M2-ATX controller by switching off the ignition, it shuts power off completely after 5 seconds, no hibernate signal.
