Always Hibernates
  • Always Hibernates
    So I got everything installed and have it all working great except the ignition off settings. I have the jumper on the M2 set to 5sec/2hours, and today I had it off for around 3 or 4 hours and it was still hibernating when I started my car. Is this normal? I thought the M2 would shut the pc off after 2 hours?
    Thanks, Alex
    Something in Windoze is interfering with hibernation.
    Could be an application, a service or a driver.
    How about the Wiki?
      Alright I will take a look.
      In the power options do I want to set "When on/off is pushed" to hibernate? I'm confused about how to set up the XP power options. I'm using XP home.
      Thanks, Alex
        If its hibernating when you turn the car off then the windows power settings are correct.
        You need to figure out what is preventing the hibernation like DarquePervert said. Best place to check is the windows event viewer to see whats crashing or hanging.
        openMobile - An open source C# Front End (why choose openMobile?)
        - Always Recruiting Developers -
        Like what you see? Donations are always welcome
