M2-ATX to power monitor
  • M2-ATX to power monitor
    How can I power my Lilliput 889GL-80NP/C/T 8" Widescreen (16:9) VGA Touch Screen to run uninterrupted using my M2-ATX power supply and a ZOTAC IONITX-F-E Atom N330 1.6GHz Dual-Core Mini ITX Intel Motherboard with 4gig memory and a 60gig SSD harddrive? I tried to power it using the yellow 12v wire inside the computer but my monitor shuts down after a few minutes, tried several times same reaction. When I plugged my monitor in the supplied AC wall transformer it works perfect. According to MO-CO-SO where I bought the M2-ATX it says that the Mini ITX case has a connection for running a monitor through the power supply, could not find that connector, so there must be a way to power this monitor using the M2-ATX board.
