M2-ATX Not sending shutdown when ignition off
  • M2-ATX Not sending shutdown when ignition off
    Sorry if this is a repeat question because I feel it is, but a quick search and I couldnt find a solution. I will continue to search, but in the mean time here is my problem.
    I have J1 (RED) wired directly into my battery
    J3 (white) to my ignition (+ when key on)
    J4 (Black) Directly to ground
    J8 To Motherboard power
    J10 has a jumper on "A" which is P1
    I have just reinstalled my carpc into a new vehicle that I bought. Before this I always ran this setup in P0 (dummy) mode and had the positive (J1) on a relay/switch so I don't know if P1 /ever/ worked correctly.
    With everything off, I turn the key to "IGN/ON" and PC & screen boot up fine. when I turn the key to off position my monitor shuts off, but PC never even tries to sleep/hibernate/OR shut off. I have verified with a meter that it does infact lose power when I turn the key off so I'm thinking maybe the M2atx is bad? I have verified also that my power settings in the control panel are set to "Hibernate when power button is pressed"
    Also, if I manually hibernate/shutdown/sleep I find that the only way to boot the pc again is to pull the fuse thats going to J1 (remove power completely) then reinsert it.
    Anyone else having the issues I am?
    Switched a couple settings around in the bios and it works fine now.
      what settings did you change? cause i'm having a very similar problem .... I have a zotac mobo btw.
        Honestly I don't remember, But it's back to not shutting down again so i have unplugged it and haven't powered it on in a few weeks because it ****ed me off so much.
