Trying to add SSD to M2-ATX PSU & VIA EPIA SP13000G Mini-ITX Motherboard
  • Trying to add SSD to M2-ATX PSU & VIA EPIA SP13000G Mini-ITX Motherboard
    Hi guys, any help would be appreciated.
    I have
    M2-ATX 160W Intelligent DC-DC PSU
    My current old HD is a Highly reliable Seagate 40GB 2.5-inch ATA-100 EE25 Automotive Grade extreme Conditions and did not need power.
    I have a 64GB SSD that I would like to swap my 40GB with, I have my case open but I am confused.
    I see that my motherboard has SATA powers, but I don't see any type of power for SATA or even a Molex to get an adapter for. The only thing I see is the following
    Click image for larger version
    Can I somehow convert this to power my SSD or am I missing something, any help would be appreciated!
    You can get a adapter for your molex connector that was plugged into your old hard drive to convert it to SATA
    http://www.monoprice.com/products/pr...FQSf4Aodxl8Alw
    The connector you have there is for a floppy drive and wouldnt work.
      Thanks for the reply, thats the issue, there is no molex connector, my previous hard drive did not require a seperate power cable
      After doing some searching, I noticed the M2-ATX psu has a seperate P4 connector that is unused, maybe I can use a P4 to Sata Power cable?
        If you email mini-box, you can get a replacement M2ATX harness, which has a hard drive connector, and I think the new ones even have a SATA power cable.
        RevFE
        My Shop
          All the M2 ATX cables I have seen came with molex plugs so you must have something old then
            I purchased this psu 02/2009, there are no molex connectors on it.
              I just sent them an email, thanks for the advice guys, hopefully they can give me a hand.
              Worst case scenario I guess I could go from the P4 connector to Sata Power and just buy a cable for it tomorrow.
                Odd I received a reply back from mini-box and they replied with the molex to sata adapter. Am I missing something from my harness because my 20pin power goes to (2) 4pin mini molex connectors, I do not have a regular molex like most people seem to think I have lol
                  Yes you are missing something from your harness. You don't need an adapter, you need a REPLACEMENT m2atx 20pin-20pin harness, which comes with molex and sata connectors. Top cable here: http://resources.mini-box.com/online...s/M2-ATX-2.jpg
                  RevFE
                  My Shop
                    malcom2073, thanks so I am not going crazy
                    I checked on their site in psu's section and accessories, didn't find it. Does mini-box or someone else still sell these? Also do you know if any stores would sell that locally so I can upgrade my carpc this weekend while I am bored
                    Thanks again man, appreciate it!
                      Nope, I've yet to be able to find it anywhere else, and minibox doesn't sell it on their website, you have to specifically ask for it via email and they'll sell it to you.
                      RevFE
                      My Shop
                        Man you guys suck at google. http://www.mo-co-so.com/20-pin-ATX-P...s-atx-2020.htm
                        Give me a prize!
                        Tidder
                        Try RevFE
                          Not sure why nobody commented on this. Most all laptop hdds and SSDs I've ran into use 5v only. P4 is only 12v and ground. And normal 3.5" sata drives require both 12v and 5v.
                          Tidder
                          Try RevFE
                            Tidder, thanks for the reply I appreciate. I found a P4 to Sata power adapter, are you saying not to use it for my SSD? If not back to plan xxx lol
                              Do you have a link you can provide to the cable you found? I don't see how that could work. Laptop SATA hdds require 5v, desktop SATA hdds require 12v and 5v. P4 connector only provides 12v so either its providing only 12v to the SATA connector's 12v or it's supplying 12v to the SATA connector's 5v. Means it would either just not work, or worse, fry the drive.
                              Tidder
                              Try RevFE
