Will an M4ATX be enough to power this? I'm not sure...
  • Will an M4ATX be enough to power this? I'm not sure...
    CD/DVD Drive: http://www.newegg.com/Product/Produc...82E16827118028
    Motherboard: http://www.newegg.com/Product/Produc...82E16813130165
    Memory: http://www.newegg.com/Product/Produc...82E16820148163
    CPU: http://www.newegg.com/Product/Produc...82E16819103221
    Hard Drive: http://www.newegg.com/Product/Produc...82E16822136197
    PCMCIA to PCI (to be used with EVDO Mobile Broadband Card): http://www.amazon.com/StarTech-com-C.../dp/B00068YUPM
    Lilliput 8" touchscreen: http://store.mp3car.com/Lilliput_809..._p/mon-005.htm
    I think it'll be ok.....but I want to make sure I'm not going to starve the system or cause the power supply to fry
    Planning: [|||||||||-] 90%
    Purchased: [|||||||||/] 99%
    Installation: [|||||||||-] 90% (when is anyone's project ever REALLY done...)
    It should be plenty. None of those components are big power guzzlers.
    My Nearly Complete Car:
    http://www.mp3car.com/vbulletin/show...ed-car-pc.html
    Micro Control Center... Control Your Car Across the Internet
    http://www.mp3car.com/fusion-brain/1...-internet.html
    Website: (It's a work in progress, really. All my projects have taken me from ever really developing it.)
    http://paulfurtado.com/
      that's what i figured, but always better safe than sorry, right?
        Have a quick question though, why not use a Expresscard to USB adapter? Unless you already have the AirCard. That way you dont tie up any PCI slots. Instead you can use it for a soundcard or something.
        EDIT, nevermind, hehe, I see it has 2 PCI slots.
        ALSO, how many watts is the M4ATX? Your processor eats up 65W, also the MoBo also eats up watts, not sure how many though. You also have to take into account the amount of USB devices, HDD and CD ROM and anything that connects to the PC.
        1X Ainol Novo Flame Tab
        4X MK808b
        3x Perixx Touchpads
        3x 7 inch Screens
        1X 7 inch motorized Screen
        1x Win 7 PC
          that's beside the point........i'm using onboard audio because it has the Realtek ALC888 HD chipset...
            The M4ATX is a beast for a car power supply. It does 250 watts. His setup probably won't even touch 100 watts.
              I have a BIOSTAR TForce TF7025-M2 motherboard and it has the
              Realtek ALC888, I have never been able to get it to output surround
              sound or digital of any kind - tried all the drivers I could find, I finally
              gave up, I will ether replace the motherboard or add a sound card that
              works, apparently Linux is affected also
                Did you actually tell windows to use the digital output rather than analog?
                  oh yea, I did everything I could find, nothing worked,
                  you can Google it, a lot of people have had problems
                  I went from an older motherboard that had Dolby Digital/Surround
                  and all that, and it worked perfect, never had any problems, then I
                  got a new motherboard and parts, and all I get is stereo kinda
                  mad about it
                  In the "Control Panel" under "Sounds and Audio Devices" under
                  "Speaker Settings" and "Advanced" I have it set to "5.1 surround
                  sound sound speakers"
                  And in the "Realtek HD Audio Manager" under "Audio I/O" under "Digital"
                  I have it set to "Output Digital Audio Source"
                  I only get stereo
                  My Surround Amp shows the motherboard is only outputting
                  "Dolby Pro Logic" and never any thing else, my older
                  motherboard was always "Dolby Digital" it was able to take
                  stereo and fake surround if you wanted
                    mad about it
                    I only get stereo
                    Have you took a look at the Default Device for Sound Playback in the Audio Tab of Sounds and Audio Devices?
                      In that TAB, the only thing in there is "Realtek HD Audio output",
                      nothing else listed
                      My dad uses the same motherboard and it has the same problems
                      I don't mean to thread jack, I just wanted to warn of potential problems
                        i'm not concerned about surround sound quality audio.....i just specifically wanted front/rear/sub, which i can definitely obtain using the ALC888 chipset
                          When I say stereo, I mean 2 speakers and thats it, I a have 5.1 setup,
                          but only the left and right work no matter what I do
                            i see.........i'll have to do some testing.....
