M4 Questions and help
  • M4 Questions and help
    So im looking at purchasing the M4 for my new carpc that is going in my 05 neon show car, and i have a few questions about wiring it for auto turn on as well as a few other concerns.
    1) can the ignition wire be hooked to the remote wire for my amps (with a relay)
    2) if i cannot do #1 is there a way to wire it so that i can have it running without starting the ignition.
    3) is there anything else i need to purchase to do the above other then the ATX case for it?
    1+2.the ignition trigger gets connected/powered just like a amp trigger connection, so yes, there should not be any issues connecting it that way.
    3. switches, and power calculations/power adapters to be sure that you can run the required amount of time without starting the motor.
    next project? subaru brz
    carpc undecided
      Thanks!
      im not too worried about how long it will run as i have a ac to DC converter for running my A/V at shows
      but does the M4 come with everything i need to hook it up to my computer (other then power and remote wire) to make it turn on and off?
        it should-- it includes the 20-pin atx power cable+ p4 power adapter, and the small power-button jumper cable. though, if i remember right, the usb connection cable is not included, so you either need to make one, or order one separately.
        carpc undecided
          where can i order the usb cable? only thing i could find on here is how to build one, and im not that comfortable doing so....
            Here's a link to where you can get it in the MP3Car Store: http://store.mp3car.com/M4_ATX_USB_C..._p/cbl-068.htm
