Device : 12v .08A input
  • Device : 12v .08A input
    I have a device that gets its power from a power brick that the input is 120v 60Hz 0.21 A and the output is 12v 0.8 A
    My thought was if I put this to the battering using a plug into the back of the device it should be ok. Or should I put something inbetween it and regulate it more? I also have an M$ power supply I plan on using on my car pc.
    Thoughts?
    Regulate it, that 12v output is 12v not automotive 12v which can fluctuate anywhere between 11.5v-14.6v and will blow the power supply in the computer. Good luck SNO
