FAQ: My Lilliput won't calibrate correctly.
  • FAQ: My Lilliput won't calibrate correctly.
    If you're having a problem where your Lilliput (even if brand new) looks like this when you calibrate it:
    Image stolen.. er borrowed.. from yamathegreat in this thread.
    Then it looks like you need a new touchscreen overlay.
    You may have some luck contacting whomever you bought the screen from and arranging a return, but if not the replacement panel can be found at DigitalWW... here.
    They're a cinch to install. Carefully disassemble your Lilliput and remove the taped on touchscreen panel. Now remove the protective covering on the replacement panel and secure it on the screen with a little tape of your own. Hook its little connector up just like the old one was and reassemble your Lilli and you're good to go. Easy as that.
    Edit: I'm sticking the word "calibration" in here so this thread will show up in searches
    Progress: On hold while I pay off my new PowerBook :D
    Part List:
    VIA MII10000 - 512MB - 20Gig 2.5" - Rikaline 6010 - 7" Lilliput - CNX-P1260 - Alpine 4ch Amp - 4 Gauge wire and fused distrobution block.
    what lilliput has these issues?? the old or the new??
    View My Blog
    Click for 2GB FREE on-line storage!
      For me it was the old one (619). The newer (629) may or may not have the issue also, I do not know for sure.
      Part List:
        For the most part the new ones have been relativly trouble free compared the massive amounts complaints and threads about the old ones. They sourced a different touchscreen overlay that holds up better to heat and is less prone for failure.
        Disclaimer. This if not out of experience but from reading other peoples evaluations and posts
          The Lilliput 619 has been through about 5 revisions in the past year and touchscreen are now more reliable then the Xenarc's. The 619 and the 629 Lilliputs both use the same internals they are not “older” or “newer” but rather different casings.
