FAQ: What is Bit-Perfect?
  • FAQ: What is Bit-Perfect?
    Bit-perfect: This is how the audio stream will come from your PC. If you are running bit-perfect, you will have a more true reproduction from the media that you are playing. If you are looking for the best possible audio from your system, you will want to know about bit-perfect.
    By bypassing the Windows KMixer and running either ASIO or Kernel Streaming, you are ensuring that you are hearing the music as it was encoded on the CD.
    The downside to this? If there are errors on the CD, you will hear them as there is not any correction being made to overcome the error.
    In essence, by runinng bit-perfect, you are ensuring that there is no difference in information between the CD that is being read and what makes its way out of the digital output of your sound card.
    The quality of a sound card can have an effect on the quality of the output, even with bit perfect playback enabled. The timing and/or jitter can vary between sound cards, usually with the lower end sound cards having a higher likely hood of jitter.
    KMixer
    KMixer:The KMixer is a part of Windows that enables your computer to take multiple audio sources and play them back at the same time and at the same bit rate. The KMixer is also how Windows handles your volume control. Regular CD audio is 44.1 kHz. Many times, due to poorly written drivers, sound cards that will interact with the KMixer wil cause this 44.1kHz data to be resampled to 48kHz. Obviously this will result in an undesireable result when trying to achieve the upmost in sound quality. The mixing algorithm as implemented by Microsoft has been shown in many cases to only have a signal to noise ratio of about 92dB. CDs have a signal to noise ratio of about 96dB (technically 97.5dB). The KMixer effectively reduces the data from 16bit to 14 bit.
    To bypass the Windows KMixer you either need to use ASIO or Kernel Streaming.
    ASIO
    ASIO:ASIO is a professional audio standard that provides for a low-latency audio stream from the computer. ASIO bypasses the KMixer entirely. ASIO is used by the recording industry as a standard. For more information on ASIO, please see here MP3Car.com Thread
    Kernel Streaming
    Kernel Streaming:Kernel Streaming is just about the same thing as ASIO. It is Microsofts answer for being able to play audio files in a bit perfect format on a Windows machine. Kernel Streaming make efficient real-time streaming of audio possible. However, Kernel Streaming is not an industry standard. ASIO will have many more supported plugins avaliable for various media players. Kernel Streaming requires less CPU time than the regular 'wave out' method.
    What you need to achieve Bit-Perfect
    Jan Bennett
    Software
    Media Players That Support Kernel Streaming
    Foobar2000
    Foobar2000 supports kernel streaming natively. To activate it do the following:
    Foobar 2000 -> Preferences -> Ouput -> change Output Method to Kernel Streaming.
    Then you will need to change the sound device to the sound card you are using.
    If you are experiencing audio dropouts, you may want to change the buffer length. The default is 2048ms.
    WinAmp
    WinAmp will support kernel streaming with the addition of a kernel streaming plug-in.
    Kernel Streaming Plug-ins for WinAmp
    • WinAmp 2: You can find a Kernel Streaming plug in for WinAmp 2 available here from Steve Monks - http://www.stevemonks.com/ksplugin/
      For some discussion or possibly for some support on this plug-in, check this thread - Hydrogen Audio Forum
    • WinAmp: For a Kernel Streaming plug in for WinAmp, as well as FLAC and VolumeLogic - Torrent File
      A note about this plug-in for WinAmp: Sometimes the play list will not advance automatically when a song finishes. You will have to manually press Next or select another song. This can be resolved by combining the Kernel Streaming plug-in with the VolumeLogic plug-in also included in this torrent. In Winamp’s output plug-in list, double click on VolumeLogic (setting it as the output plug-in for Winamp to use) and a window will pop up asking you to select the out put plug-in. Select Kernel Streaming from here. This will fix the play list advance issue so everything works. When you double click a song, however, rarely, it will not start. Just press pause twice and it will start like normal.
    Media Players That Support ASIO
    J. River Media Center
    J. River Media Center Media Center natively supports ASIO.
    Tools -> Options -> Playback -> change Output Mode to ASIO
    Then you will need to change the sound device to the sound card you are using. Or, if you are using a ASIO -> KS wrapper, choose it.
    Foobar2000
    Foobar2000 does not support ASIO natively.
    Foobar2000 ASIO Plug-ins
    These plug-ins can be found here: http://otachan.com (For a translated version of the page, see here:Translated Page)
    Foobar2000
    WinAmp
    Winamp does not support ASIO natively.
    WinAmp ASIO Plug-ins
    WinAmp 5
    Options -> Preferences -> Output -> change the output plug-in to the ASIO Output Plug-in -> Configure
    Thread Priority - for audio only, Time Critical should be fine.
    Turn resampling off, if it is on, you will no longer be playing bit-perfect.
    Jan Bennett
      Using an ASIO Wrapper
      Since many sound cards do not support ASIO natively, you will need to use an ASIO wrapper. There are a few options for this:
      These directions were provided by darklordjames for ASIO4All:
      Upon installing ASIO4ALL, you will get a control panel for it on your desktop. Open that up and set it up as follows. The buffers I have described here are huge, but it is better to have large buffers when trying to get it to work, and then work the buffers down once you know things are functional.
      • Audio Device = Your Sound Card
      • Sample Rate = (greyed out)
      • Buffer Size = 2048
      • KS Buffers = 4
      • Always resample @ 44.1khz = off
      • Disable input = on
      • Force 16 bit samples = off
      • Direct DMA Buffer I/O = off
      Now, go grab Winamp and the ASIO plugin and set up the plugin as described below. Try playing an MP3/CD Audio track and see if you have success. It works? Good! The battle is half won! If you are using SPDIF in your setup, and have a reciever that does DTS decoding, then you need to do a 44.1 khz DTS test. If the DTS test passes as well, then you are one step closer. Do one last test with a DVD or Divx with an AC3 track and see if that still works. If it does, then you are good to go. Welcome to the bit perfect world! At this point you should fiddle with the buffers in the ASIO control panel and Winamp to see how low you can get them without noise/dropouts. Of course you can also use other ASIO-enabled programs as well now, but I will leave the details of that up to you. You know the concept of getting this to work, that was my aim.
      But let's say you weren't lucky, and things aren't working. Or AC3 output is now dead. Uh-oh. First, double-check your settings. The ASIO4ALL Control Panel is dynamic, and as such it can be used while Winamp is open and any changes you make will take place immediately. There is also one other thing that may need to be done. There is an exploit in the Envy24HT-S driver's Control Panel that you can take advantage of, but I believe this is only valid for SPDIF output. Go to the Digital Out tab and select PCM Only. Then select the 8 Channel output tab and go to Sample Rate & Immerzio 3D. Under Sample Rate Select uncheck Automatic, select 44.1khz, and re-check Automatic. Go back to the 2 Channel tab and go to Digital Out. Select AC3 or PCM Autoselect (48khz only). This should result in the Envy24HT-S Control Panel essentially being tricked into letting AC3 or PCM at 44.1 and 48khz autoselect between eachother. I don't know why it doesn't just work like that in the first place, but, whatever.
      Thanks to Signal and B3b0p for the above Control Panel trick!
      Bit-Perfect Audio Codecs
      • ACL880
      • ACL882
      The AC97 codec is NOT capable of bit perfect playback.
      Rules of Thumb for Bit-Perfect
      • When Bit Accurate mode is applied to the playback, adjusting the volume control or applying EAX effects will not have any effect on digital output signals.
      • Once Bit Accurate playback starts, the digital output sampling rate is automatically set to the current playback's sampling rate regardless of the current digital output sampling rate.
      • Bit-perfect can only truly be tested using the tos-link out of either your sound card or a compatible audio codec for onboard sound for some motherboards and a DTS-decoder.
      • Any software DSP or sound processing will cause the benefits of bit perfect to become null.
      • Play with the buffering options. The buffer settings will vary depending on your system. Lower buffers are better, obviously as you will have a lower latency, however, if they are too low you will run into issues with audio drop-out with a system that is under a heavy load.
      • Bit Accurate mode is only applicable to .WAV files with the following specifications:
        • Stereo Format
        • PCM audio data
        • 16-bits and above (maximum 32-bits with 24-bits resolution)
        • 44.1, 48, or 96 kHz
      Testing Bit-Perfect
      If you have successfully achieved bit-perfect playback, you should be able to play a DTS file off of a CD (16-bit, 44.1kHz). If you only get static from trying to play the file, then you know that you haven’t achieved bit-perfect playback.
      Bit-Perfect CD Players
      This is from the Alcohol Software web site. Those listed under the 120% column are considered to be bit-perfect capable CD players.
      Jan Bennett
        Resources
        Jan Bennett
          A virtual feast of information! Thanks Jan!
            This is gonna be put in the FAQ forum, right?
              It's actually already written into a wiki that will be going up on this site in the future.
              I will move it to the FAQ in a few days once I'm sure everything is 100% accurate.
              Jan Bennett
                Good info...finally decided to comment after soaking in the details.
                For those running creative labs sound cards:
                The sound card processes at 48Khz and never at 44.1Khz:
                I would ask what is better but instead which is prefered?
                Bit Perfect vs. software resampling 44.1<->48kHz
                Both can use ASIO, but from what I understand you can't have both bit perfect and resampling.
                Here's is some good reading about resampling comparisons on the new x-fi cards.
                http://www.digit-life.com/articles2/...tive-x-fi.html
                System always under construction
                  I'm not 100% on which is the preferred method, but I would imagine bit-perfect.
                  Not having anything touch the audio signal means nothing is likely to fudge it up. It's a good question though and worth looking into!
                  Jan Bennett
                    I guess it depends on if you want the soundcard to do any processing at all.
                    You are correct that anything done to change/alter the original signal is destructive...but the creative cards as well as many others seem to sample to 48 or even 96kHz to do processing on the signal unless you use one of the cards you have listed or a pro sound solution.
                    I was playing with the ASIO and the KX project last night and I am left with one question...
                    If you fix the sample rate to 44.1kHz, is that only on the digital/spdif output or does that work for the analog too? I was listening to Sheffield Drive through a pair of decent headphones and I wasn't sure if it was doing anything that I could notice. I read and read and read but none of the programs specify. Any idea?
                      Originally posted by RedGTiVR6 View Post
                      Foobar2000
                      Foobar2000
                      Maybe I'm missing something here, but...
                      Originally posted by otachan.com
                      Plug in for foobar2000
                      foo_ddecontrol.dll Ver. 0.41.1 DDE short story Rawlplug in (2006/9/1)
                      foo_playlistclear.dll Ver. 0.08 Play list deletion plug in (2006/8/5)
                      foo_dsp_ssrc.dll Ver. 0.57 SSRC plug in (2006/8/16)
                      None of the files under the "foobar2000" heading on that site are labeled asio
                        dono - it's possible that the page has changed. However, if you click on the links I provided for each download...you will get the ASIO downloads for Foobar.
                        Jan Bennett
                          I just wanted to point out some new info.
                          The new Vista operating system has done away with the Kmixer and has a new core program called Audiostack. Vista was designed for high end audio in mind and it may make bit perfect obsolete.
                          1999 Black Pontiac Trans Am
                          CarPC's in F-bodies
                          How To Relocate Climate Controls on the 97-02 F-body Cars
                          (AMD Sempron 3000+, Opus 150)
                          Car PC system is out, Alpine system is in.
                            Can you run Bit Perfect with a USB DAC? Specifically the Silverstone EB-02
                              Ok, i've just asked a question in another thread regarding sound quality and as a result was told to do a search on Bit-Perfect here... if Vista truely does have a more advanced way of dealing with high end audio then it could influence what operating system goes on my carpc and pretty much all the components that will go into the PC, can anybody provide some more information on Vista's new technologies/how they compare to the bit perfect option?
