iGo Stowaway USB Keyboard
  • iGo Stowaway USB Keyboard
    This review is for the ThinkOutside iGo USB Folding keyboard re-branded as Fellowes. There are a few other companies that this is re-branded with though (i.e. targus, etc.) There is a version that uses bluetooth that is exactly like this one (except uses batteries) so this review will cover both models, as well as those with PDA versions.
    Here's the link to the Bluetooth Version on iGo's website (can be found many other places.)
    http://www.igo.com/product.asp?sku=3104369
    The model I have is the "Fellowes Stowaway Portable Keyboard Designed and Manufactured by Think Outside, Inc." SKU 90190.
    Specs from the website:
    Size Closed - 5" x 3.5" x .09" (128mm x 90mm x 23mm)
    Size Open - 13.8" x 5.1" x .5" (350mm x 129mm x 12mm)
    Weight - 10.7 oz (303 g) (I think this is not correct, I will post my own findings when I post pics.)
    MSRP - $129.99 for the bluetooth version
    Review:
    The unit I received came with the USB cable, and the User Manual. The bluetooth versions come with a AAA battery instead of the USB cable, and includes a carrying case and driver CD.
    When closed, this keyboard is really small; only about the size of a 3.5" Desktop hard drive. There is a small latch on the side of the unit to open it up, and it folds out into four sections. The outer sections then slide in towards the center sections and clip into place. My unit has the usb cord which attaches to the middle left section at the top. Bluetooth units have a space for the battery instead.
    Connecting to the computer was easy for the USB version; plug it in, that's it. However, on my Dell i6k I had to use the rear USB ports and not the side ones, otherwise it wouldn't work. The bluetooth version is a few more steps, but easy if you've ever used bluetooth before, and if not, the user guide helps walk you through it pretty well. The USB cable version's cable is quite short, only about 24" long. This forces most to use an extension cable, however it will depend on your setup.
    The keyboard has a full size qwerty key layout, with a few keys that are moved or modified in the interest of saving space. The "1" key is about 60% the width of the rest of the numbers, which seems strange since it appears there is space for a normal size key (the track to allow the piece to slide is underneath.) The "\" key is also this width. The "Del" key is moved to the right of the right "Ctrl" key, which takes some getting used to. the "~`" key is also moved in between the right "Alt" and the right "Ctrl" keys. The direction arrows are the same width as the "1" key, and also take getting used to for spacing. Lastly the "Home", "Pg Up", "Pg Dn", and "End" keys are located at the far right of the keyboard. Also this keyboard has a "Fn" key, just like most laptops do. See images for examples. The keys travel the same distance as a normal laptop keyboard and have a scissors type connector on the back of each.
    While typing a normal e-mail, I found myself making a few more mistakes than with the laptop keyboard, but not by much. Mostly this attributed to the fact that the backspace key is a little smaller than I am used to on the laptop. Overall this keyboard feels just like it is supposed to. On a flat surface the keyboard won't flex or bounce, but having it resting on my lap, I found that it would bounce a little with my key tapping, which wasn't a bad thing, just something I was not expecting. This is way better than trying to use a flexible rolling keyboard though.
    When the unit is closed, you have to slide the outside sections outward and fold it up like a "W" then click it closed. When you close it, all the keys are pressed down so that it can be as slim as possible. This makes it a little difficult to close with one hand, which is not a problem most of the time. The only thing I don't like about this design is that when I close it, the latch takes a little force to get it to close, and sometimes I feel like it will eventually break. Hasn't happened yet, and probably wont, but it makes the unit feel a little cheap. (Although other than this, the unit feels very well made.)
    Comparing this to a rollable keyboard I used a few months ago, I would definitely recommend this keyboard by far. The rolling one doesn't stay rolled well, unless you band it or have a case, and you need a flat surface to lay it on. Also the flexible keys don't feel like a normal keyboard does. The rolling keyboard left me limited to about 15-20 words per minute, while with this folding keyboard I was closer to 50; to compare, when I use a standard desktop keyboard, I can usually type about 60 or so words per minute.
    My overall impression with this keyboard is that it is a great solution for those of us that want to save some space and not sacrifice too much in usability for a keyboard in the car. It's small lightweight, and replicates the laptop keyboard nicely. There are mini keyboards out there, but have smaller spacing, so the experience is a little different. The price is a little higher, but it's worth every penny. I found my keyboard on eBay for $25 with shipping. Most of the bluetooth versions are going for about $50 or so.
    I give it a 4.5 out of 5. The only bad marks for this come from the odd placement of some keys, and the feeling that it will break something when I close it.
    Pictures:
    2007 Chrysler PT Cruiser TE
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
    Favorite thread EVER!
    As promised, here are the pics:
    Keyboard closed
    Open with keyboard not locked
    Keyboard locked into place, also notice the placement and size of keys on the right
    Oddly small "1" key
    Short USB Cable
    Middle joint does not lock into place
    Size comparison, full size, standard desktop keyboard on top, the stowaway, then a roll-up keyboard for my old Samsung Palm Phone.
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
      Posted Pics.
      Any questions feel free to post them here.
      Thanks.
      Car PC Progress:
      View my
      Worklog
      Road Runner Skins
      Website
        I was just looking for something for my car, and stumbled upon this. Great pictures, worth 1,000 words.
        _______________________________________________
        All installed, and ready for visitors. Infill G4 in a 2007 Saturn VUE
          I love it, I was looking for something that could fit in my center console, and I kept looking at the roll-up keyboards. I didn't really like the one I had for my samsung i330, so I kept searching ebay, and found this. It types just like my laptop keyboard, so I can be pretty quick with it. They've discontinued the USB version that I have, but the Bluetooth version is the same size. Keep your eye out on ebay for this. Well worth any price you pay for it.
          (The pics took a while since my camera was "borrowed" for 4th of july pics, and wasn't returned until last night...)
          Car PC Progress:
          View my
          Worklog
          Road Runner Skins
          Website
            i like the white one but the black one is cool too. it looks alittle fragile though
              the white one is the roll-up keyboard i had for my REALLY old samsung palm phone, but they make it for usb connections, ebay - roll-up keyboard or folding keyboard. The black one is the center of this review, it flexes a little, but is pretty sturdy for how its made.
              For what it is worth, it feels the closest to my laptop keypad, compared to all the keyboards I've tried so far. That was an important thing for me.
              For my use, I'm making a folding board to place it on with the mouse when I use it in the car. This board has a place for the wireless mouse too. Easy out of mdf and a simple hinge.
              Car PC Progress:
              View my
              Worklog
              Road Runner Skins
              Website
                do you have the drivers ????
                Hey man,
                I'm trying like a crazy man to make this keyboard work... the driver that came on the cd doesn't work, the one on the thinkouside site doesn't work too ...
                thinkoutside tech support is helpless ....
                if you can please post the driver you got, I'd thank a lot!
                  do you have the one pictured or is yours the bluetooth version?
                  I can try to post it soon, changing servers and it may take a while, I may just post it on a free file share server (fileupload.com etc)
                  Keep posted....
                  Car PC Progress:
                  View my
                  Worklog
                  Road Runner Skins
                  Website
                    I have the same EXACT one that you have, the serial one from Fellowes...
                    Anywhere you post it (rapidshare.com, fileupload.com) will do! Please!
                    Thanks a lot!
                      hope this helps:
                      http://jcautodesign.com/Documents/kbdclass.sys
                      http://jcautodesign.com/Documents/kbdhid.sys
                      Car PC Progress:
                      View my
                      Worklog
                      Road Runner Skins
                      Website
                        Thanks!
                        But ... could you also provide me instructions on how to install the driver ?
                          I just pulled these from my c:/windows/system32/drivers folder, so I'd think you could just move the files there.
                          I really don't know that much about this kind of thing...
                          Car PC Progress:
                          View my
                          Worklog
                          Road Runner Skins
                          Website
                            130 dollar keyboard with drivers that don't work?
                            are you trying to install it on linux or mac?
                            please provide details of successful installs ans what OS's they are on guys.
                            thanks.
                              Mine is installed on both XP and XP media center edition. Works perfect on both of those computers.
                              Car PC Progress:
                              View my
                              Worklog
                              Road Runner Skins
                              Website
