Hardware Review: nVIDIA GeForce FX5500 256MB PCI Video Card FX 5500 V29
  • Hardware Review: nVIDIA GeForce FX5500 256MB PCI Video Card FX 5500 V29
    FrontEnd: StreetDeck
    Computer: Listed in profile
    Video: nVIDIA GeForce FX5500 256MB PCI Video Card FX 5500 V29
    EBay: $40
    ______________________________________
    My company switched phone carriers which allowed me to go from PCMCIA card to USB EVDO. By doing that, I was able to remove the PCMCIA daughterboard and BAM!! Room for a video card!
    If there is any way for you to put this card in your carputer, it is more than worth it! EVERYTHING is so much faster. Navigation screens load faster, screen changes are great, even the visualizations in the background of StreetDeck run flawlessly.
    I did have to modify my case, even having to break out the dremel, but it was well worth the effort.
    If you are at all tired of slow responses in your FrontEnd software, this is the answer! The reason I went with this particular card was price vs. ability. A Geforce card for $40 with 256mb is hard to pass up.
    My opinion is my own.
    EBay: $40
    Do you have any issues with crashing? I find my system crashes which i'm assuming this is because the cpu is bogged down at 100%. I was going to just drop this MOBO, but if the new graphics card will resolve my issues then i can hold off. Any input? Also, what codec packs do you use? Also, I've been reading that this card requires 250Watts. how are you powering off a M2-atx 160w?
    http://www.mp3car.com/vbulletin/show...06-vw-gti.html
    Snowperformance.net
    vwvortex.com
      What front end? 1.1.1.0 streetdeck crashes constantly, but 1.0.9.8 is extremely stable and no crashing. Check your ram. I had crashing originally, but found the ram was bad. Turn on full test in bios.
        Here's a nice list of video cards and their tested power consumption. Unfortunatly, the GeForce 5500 FX is too old for the list.
        http://www.codinghorror.com/blog/archives/000662.html
        Software Developed:
        DS-ATX Controller Interface
        Laptop Shutdown Controller
        Considered Projects:
        TPMS Interface
        Bluetooth Handsfree Interface (WIDCOMM/BROADCOMM)
          problem with fx5500
          Ho. I cant seem to get the fx5500 working on my 7inch wharfdale. whatresolution do i set the tv (svideo) to for the screen to work?
          Thanx in advance
            800x600 or 640x480
            Now, GO GET A VGA monitor!
            Brent
            1999 Nissan SE-L - turbo toy
            1993 Nissan NX - Turbo Racer
            Standalone fuel management (AEM EMS) on both
            carPC
              i bought a video card that needs 250 watts, but only running the m2-atx. how did you get your card to work?
              01 Burb
              http://www.mp3car.com/vbulletin/work...-suburban.html
                Which video card did you pickup that requires 250 watts?
                Software Developed:
                TPMS Interface
                  PNY PCI graphics gforce 5200
                  01 Burb
                    That card comsumes between 10~15 watts of power. You should be fine as long as you don't overload any of your rails. There's a guide on here somewhere that can help you with making sure you have enough power.
                    Software Developed:
                    TPMS Interface
                      hmmm, i'll have to check and see why it wouldnt work then. Had video on the onboard vga
                      01 Burb
                        Please describe what occurs before it fails. No Post No Beep, Doesn't display in Windows, etc, etc. It'll help determine if this is a power issue or not.
                        Personally, I have a 220 watt startup/shutdown controller using an 8200 video card and it runs just fine. The card may be just seated inproperly or the motherboard might have a special port on it for P.O.S. systems. Alot of the industrial motherboards have them and you have to tell it to use AGP/PCIE instead.
                        EDIT:
                        Software Developed:
                        TPMS Interface
