GA-H55N-USB3 MB from GIGABYTE
  • GA-H55N-USB3 MB from GIGABYTE
    A Quick review of the GA-H55N-USB3 MB from GIGABYTE. Ė If itís been done Ė apologies Ė I did search!
    Mini-ITX Form Factor; 17.0cm x 17.0cm
    One of the nicest features is included with the onboard (CPU) graphics, Its the software for roll your own Display driver with all associated parameters.
    I had 800x480 for my 8Ē 16:9 LCD running in a minute or so. No Drivers no hassles.
    This MB is one of the strongest and beautifully made MB I have seen in a long time.
    I run Win7, an Intel i3 540 INTEL CORE i3 3.06GHZ, 4GB of ram and a 60GB OCZ SSD.
    The total power consumption of the system when playing a movie is 36 to 46 watts. This thing runs silent and almost cold. This includes USB devices all running from an M4-ATX 250W supply.
    SSD drives resumes from STR in 2.2 seconds under Win7.
    The MB Post takes around 15 seconds from cold boot though Ė sigh - However the SSD drive loads Win7 in 10 to 12 seconds.
    Supporting the latest Intelģ Coreô i7, Coreô i5 and Coreô i3 processors featuring the first time ever integrated graphics on chip and LGA 1156 socket(Coreô i5 and Coreô i3 processors only)
    Memory:
    1. 2 x 1.5V DDR3 DIMM sockets supporting up to 8 GB of system memory (Note 1)
    2. Dual channel memory architecture
    3. Support for DDR3 1666 (O.C.)/1333/1066/800 MHz memory modules
    4. Support for non-ECC memory modules
    5. Support for Extreme Memory Profile (XMP) memory modules
    Integrated in the Chipset: ONLY with an Intel CPU with integrated graphics.
    1 x D-Sub port
    1 x DVI-D port - The DVI-D port does not support D-Sub connection by an adapter.
    1 x HDMI port (Note 4)
    Audio:
    Realtek ALC892 codec. High Definition Audio 2/4/5.1/7.1-channel. Support for S/PDIF Out
    LAN:
    1 x Realtek RTL8111E chip (10/100/1000 Mbit
    Expansion:
    1 x PCI Express x16 slot, running at x16 (The PCIEX16 slot conforms to PCI Express 2.0 standard.)
    Storage:
    1. 4 x SATA 3Gb/s connectors supporting up to 4 SATA 3Gb/s devices
    2. 1 x eSATA 3Gb/s connector on the back panel supporting up to 1 SATA 3Gb/s device
    Up to 8 USB 2.0/1.1 ports (4 on the back panel, 4 via the USB brackets connected to the internal USB headers)
    NEC D720200F1 chip: Up to 2 USB 3.0/2.0 ports on the back panel
    Internal Connectors:
    1. 1 x 24-pin ATX main power connector Connectors
    2. 1 x 4-pin ATX 12V power connector
    3. 4 x SATA 3Gb/s connectors
    4. 1 x CPU fan header
    5. 1 x system fan header
    6. 1 x front panel header
    7. 1 x front panel audio header
    8. 1 x S/PDIF Out header
    9. 2 x USB 2.0/1.1 headers
    10. 1 x debug card header
    11. 1 x chassis intrusion header
    12. 1 x clearing CMOS jumper
    Back Panel:
    1. 1 x PS/2 keyboard/mouse port Connectors
    2. 1 x D-Sub port (Note 2)
    3. 1 x DVI-D port (Note 2)(Note 3) (Note 4)
    4. 1 x optical S/PDIF Out connector
    5. 1 x HDMI port (Note 2)(Note 4)
    6. 4 x USB 2.0/1.1 ports
    7. 2 x USB 3.0/2.0 ports
    8. 1 x eSATA 3Gb/s connector
    9. 1 x RJ-45 port
    10. 6 x audio jacks (Center/Subwoofer Speaker Out/Rear Speaker Out/ Side Speaker Out/Line In/Line Out/Microphone)
    Palm sized ainol MiniPC, 8" Transreflective PRO, Win10, Reverse camera, Dual 10HZ GPS RX's for Speed Display & Sat Nav, FM-DAB & Phone Modules, iDrive interface. T-Screen HVAC control, custom microcontrollers, microcode and FE.
    Is that 15 seconds from power on to end of BIOS / start of loading windows? Thats pretty extreme!
    Did you trial that with no usb devices plugged in, video priority set in the bios to onboard first?
    Just that I am interested in this unit, however I would use cold boot quite often (M4 only allows for 19 hours on standby, so it cold boots at least once a week).
    Otherwise, thats one excellent looking board, I have been keen on this ever since it was announced, just need to push the wife for an upgrade I think!
      Iím surprised at the time as well Ė From cold boot, there is about a 5 second delay before the CPU fan moves up in speed, at that point the normal post screen appears. From there itís pretty quick considering that the SSD runs in AHCI mode Ė not IDE. This drive/port scanning appears to be fast compared to other MBís I have.
      Yes I have on board graphics set to first.
      It makes no difference if I have no USB or 5 USB devices plugged in.
      A reboot is quick as this initial 5 second power on is skipped.
      Power on from suspend to the Win7 desktop Ė no hourglass, is around 2.5 seconds.
      Total cold boot from the SSD to the Front End on screen is around 32 to 37 seconds.
      Iíve just backed out the driveway in that time. As reversing camera does not need the PC running of course, I hardly notice the time.
      If you took off that 5 seconds and the AHCI scan you would be down to about 7 seconds. Oh well, Iím getting older and slower so maybe I donít notice it as much.
      I have been so busy building, Programming and reverse engineering the Accord Climate-Control CPU and getting everything installed that I have not had a chance to sit down and go through all settings. Maybe in the New Year.
        Thats good to know that things like USB devices doesn't change it, I know some other boards suffer from huge delays due to USB devices.
        Possibly that might clear up down the track from a bios update, but hey, if that's all that is wrong with the board, its almost nitpicking!
          Yes, quite so as itís a rev 1 Bios.
          I can only add that this is my favourite all time MB.
          That delay is the only thing I can pick with it. Itís performed flawlessly with the hundreds of reboots, running power cuts and abuse as I modified the PSU and built the final System.
            I couldn't agree more.
            I've been running this in my truck from about 6 months and couldn't be happier. As mentioned, not the fastest bootup on the block, but great features and flawless performance make up for it. I'm running an i3 530, 4gb RAM, 64gb SSD boot drive (SATAII), and a 500gb 2.5" media drive off an m2-ATX without a glich. I have the same board, processor and ram in a micro-ATX form factor running as a HTPC in the house.
            I plan to upgrade the drives to SataIII after Christmas (when I get some more money!)
            Highly recommended!
            VegasGuy
              I was hoping for a bit more from your review because it's largely a rehash of the spec sheet which we can all find. What frontend are you running? What specific USB devices do you run? What BIOS settings have you modified? How is multitasking (i.e., playing music while running GPS)? CPU load while watching a movie? Is it a 1080P movie?
                This was mainly aimed at the quality and construction of the board.
                The Front End is designed and written by me.
                The USB devices and associated Microcontrollers are all designed, built and programmed by me.
                The only commercial USB devices are a Garmin GPS RX and a Digital-FM tuner with the tuner control software again written by me for the front end.
                I donít watch movies while driving or while in the car.
                No mother-board running an I3 processor at over 3GHz and 4GB of ram should have any problem multitasking anything needed in a car-PC unless the software is crap or you are running a SMALL amount of ram.
                  Ahhh I see. Sounds like an interesting setup you got. Agreed about your multitasking comment & software being poorly written which has been experience in the past.
                  How long have you been running this new mobo?
                    To follow up with Mickz's post, here's a quick synopsis of my environment:
                    Gigabyte GA-H55M-USB3 motherboard, i3 530 processor, 4gb RAM
                    128gb Crucial SSD (boot), 500gb Hitachi 2.5 (media)
                    Windows 7 ultimate, Centrafuse 3.1, Bluesoleil 8, Garmin GMPC
                    XMPCR satellite radion, Visteon HDZ300 HD radio
                    Generic ELM327 OBDII, BU-353 USB GPS
                    Uniden BCT8 UHF/VHF scanner with custom control plugin
                    RelayPros PWM81 8-channel relay controller with custom control plugin
                    Creative HD webcam with custom control plugin
                    Clear 3G/4G Wimax with Cradlepoint MDR1200 failover router
                    DroidX with custom remote control app for Centrafuse
                    Custom video streaming app for sending live video out to my media server.
                    Over a dozen custom plugins for streaming internet media, Google services, traffic, weather, social media, RSS etc...
                    If it's not pretty obvious, this is a fairly robust machine for a carPC. I can pretty much run anything and everything simultaneously without any real problem (as Mickz said, I'd be surprised if it didn't!).
                    But if you need an example, I can encode and stream live, 30fps video from my Sony Handycam, while recording it locally and viewing it (along with my webcam) in a PIP display. I capture live GPS position data along with OBDII data and overlay it on the recording, while listening to XM radio and have Garmin provides navigation and routing. I see around 35-60% processor usage in this scenario.
                    As a side note, the M2-ATX has no problem powering this setup. If you're looking for (an admittedly) high-performance system that is VERY frugal with it's power requirements, you'd be pretty hard pressed to find a better value than this motherboard. As I said, I have 2 (one ITX, one ATX). Highly recommended.
                    VegasGuy
                      VegasGuy
                      Thanks Mickz & VegasGuy for the quick reviews. The reason for all my questions is I want my new carPC system to last a few years and handle the multitasking I plan to use (GPS, webcam encoding, etc). And when the time comes to retire it, I want to make it a regular house PC that is still usable. Sounds like this mobo is a good bet.
                        VegasGuy
                        Do you use standby or hibernate?
                        you use the M2-ATX correct?
                          Actually, until recently, I never had much luck with sleep/hibernation. Occasional blue screens, UI hangs and what not just didn't make it worth while. But it turns out the most likely culprit was some crappy serial-to-USB converters that were throwing a fit everytime I came out of hibernation. I got rid of them a few months back (finished the project I was worknig on). Recently, I have been working on a dual camera DVR app for Centrafuse and needed to test how it handled sleep/hibernate/resume. Lo and behold, everything is working great. I set the M2-ATX to go to standby (12V off, 3.3 and 5V high) 5 seconds after ignition cutoff, and to hold that mode for two hours, then power off. I set the PC to go to sleep on power off, and to hibernate after 1:30 (Win7 hybrid sleep)
                          It all works GREAT! Inside 2 hours, I get music in about 5 seconds after key turn. 40 sec otherwise. And the DVR starts recording properly too....which is good.
                          But this is all ancient history...or soon will be. I'll start installing this tomorrow:
                          ASUS P8H67-I DELUXE (REV 3.0) LGA 1155 Intel H67 HDMI SATA 6Gb/s USB 3.0 Mini ITX Intel Motherboard
                          Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) 4 x 256KB L2 Cache 6MB L3 Cache LGA 1155 95W Quad-Core Desktop Processor BX80623I52500K
                          G.SKILL 4GB (2 x 2GB) 204-Pin DDR3 SO-DIMM DDR3 1333 (PC3 10666) Dual Channel Kit Laptop Memory Model F3-10666CL9D-4GBSQ
                          128gb Sata6 Corsair SSD
                          This actually draws LESS power than my current i3 530 board! Should be some BIG fun. I'll let you all know how it goes and what the performance is like....although I already know since I'm typing this on essentially the same layout. A little more ram, bigger hard drives, but an Asus P67 sabertooth and a Sandy Bridge i5.
                          Cheers!
                          VegasGuy
                            Cheers!
                            VegasGuy
                            I have been eyballing that exact same board. Let me know how things work out.
                              Hi
                              I'm using the same motherboard with m4 -atx and windows 7. Its works great the only hitch being the post time
                              Just wondering if you have done anything (i.e change settings) to
                              a. Speed up the post time
                              b. Speed up loading windows (from hibernate)
                              The other annoying things is that when i use my iPod it takes another minute or so to initialize and freezes centrafuse during that time. Any ideas how i can fix that?
