Updates to Auto dimmer
This topic is closed.
  • Updates to Auto dimmer
    Download Auto dimmer
    What is Auto dimmer?
    This program locates the position of the sun from your position and dim the monitor if its dark.
    Also you have a manual mode and a autorun setting.
    Screenshots
    Bug Fixes in version 1.1
    custom brightness can be set (20%-50%)
    Now the Timezone will be considered (please set this in dimmer.ini on utc=)
    If Centrafuse or other programs change the Brightness, dimmer change it back again
    All settings like brightness and the last active mode will be saved on exit
    more stable
    description update to:
    You just have to set the latitude and longitude in the dimmer.ini
    If you don't know how to find it use this site: http://itouchmap.com/latlong.html
      New features in version 1.1
      Automatically dims your monitor depending on your position
      A 20% - 50% Dim value can be set
      Autorun setting
      Manual and auto mode
      Works perfect with Centrafuse and other Front Ends
      Overwrites brightness value if any other prgram change the brightness (Centrafuse for example)
      Latitude/Longitude and UTC timezone must be set in dimmer.ini
        -Latitude/Longitude and UTC timezone must be set in dimmer.ini
        -Overwrites brightness value if any other prgram change the brightness (Centrafuse for example)
        -Works perfect with Centrafuse and other Front Ends
        -Manual and auto mode
        -Autorun setting
        -A 20% - 50% Dim value can be set
        -Automatically dims your monitor depending on your position
          Bug Fixes in version 1.2
          Solved hibernation problems, because path to ini file lost
          ini file now automatically created if it not exists
          support update to:
          http://www.mp3car.com/vbulletin/software-software-development/146117-auto-dimmer-lon-lat-position.html#post1430095
          version update to:
          1.2
